oil pressure guage
I just bought me a 94 jeep grand cherokee ltd ...the oil pressure guage does not work..it does not move at all. What can it be??..
could be your pressure sending unit/switch. Mine is located above my oil filter. I was getting bad reading and I replaced the switch and solved the problem
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG--- |
I have had this before (I sell Jeeps). It is either your sender OR it is your cluster (the entire information backdrop). If it is your sender it's like $50 for a new one, if it is your cluster, you have to get it from Jeep and its about $200. Hope this helps. Good luck. If it is not moving at all, it sounds like the cluster. If it were moving erratically back and forth, usually the sender.
-Anthony |
Re: oil pressure guage
Oil Pressure Switch (my 94 5.2L) was $23 (autozone). it is most likely either the switch or or the wirign from the switch is bad.
