Speedometer and 4X4 On Light
Just got though changing out my engine,(3.0) adding Downey headers and doing other mechanial repairs to the trans and transfer A340H, nothing internal. Both the speedometer and the 4X4 on light in the dash stopped working. Everything else works fine and 4WD is engaging. Trying to figure out what these two have in common that might be causing this problem. The light bulb is good. OD, ECT and AT Temp lights work!! Anybody got an idea?? These factory electrical diagrams leave alot to be desired!! Any suggestions will be appreciated!!
92 Chevrolet Silverado 5.7 Automatic 2X4 |
I'm reading codes 14, 21 & 42. The 21 is explainable since the o2 isn't hooked up yet. The 14 IGF signal from igniter is not input to ECM for 6 consecutive ignitions & 42 SPD signal is not input to the ECM for at least 8 seconds during high load driving with engine speed between 2,750 rpm and 4,000 rpm are the ones that I can't explain!! Help needed can not make heads or tails from this FSM. Need something a shadetree mechanic can understand. As you can tell these computers aren't my cup of tea!! Open for suggestions that I can understand. All connection are in place as best I can see. Will get under there and hand check each one for good clean connection!! Thank you!!
Re: Speedometer and 4X4 On Light
Found the problem on codes 14 & 42. Terminal SP1 at ECM wasn't grounging. Does anybody know where the transfer on indicator switch is located on the 94, 3.0, 4X4, Auto, A340H trans?
Re: Re: Speedometer and 4X4 On Light
Rid of all codes, speedometer working and still trying to find out what controls the 4WD indicator in dash. Bulb good, 4WD working and no ADD on vehicle. A340H auto. Has anyone got any idea if there is a switch that controls the indicator and where it might be??
