Old 02-14-2005, 08:40 PM
medic6 medic6 is offline
Unhappy 93 4x4 4.3 W running problem
I just replaced my upper manifold gasket on the because of a leak. Why I had the manifold off I changed the gasket on the egr valve. I also changed the coolent thermastate and gasket. I checked the vacume hose by the distrib., the other one by under the tps, the pcv and the brake booster all are on. The problem I had was check engine light code 35. I found the leak at manifold and fixed. Now I have differnt problem no codes now runs perfect until operating temp and when driving won't shift. Drives great until normal temp.
Old 02-14-2005, 10:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 93 4x4 4.3 W running problem
What year? engine?
Please give us all the information.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-14-2005, 10:15 PM
Re: Re: 93 4x4 4.3 W running problem
Originally Posted by BlazerLT
What year? engine?
Your screwing with me arn't you its in the subject field.
Old 02-14-2005, 10:16 PM
BlazerLT's Avatar
AF -Advisor
Do you have the vacuum or computer controlled transmission.
Old 02-14-2005, 10:18 PM
how would I find that out
Old 02-14-2005, 10:24 PM
Re: Re: Re: 93 4x4 4.3 W running problem
I noticed that it doesn't have a kick down cable does that help
Old 02-14-2005, 11:29 PM
BlazerLT's Avatar
AF -Advisor
You must have a computer controlled transmission.
You have conflicting points in your first post.
Does it shift or not properly when up to temperature?
