Old 02-14-2005, 08:20 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Car making New sound
So the other day I driving on the expressway, (seen a S2000 and a STi get pulled over for racing), and the car started making noise. When I turn the car, like around a corner, it makes a clicking noise. or more like a tumping noise. And the sterring wheel vibrates pretty bad. Its also vibrates when accelerating. Im taking the car in tomorrow to get some work done, but does anyone have any thoughts on what it might be?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-14-2005, 08:28 PM
Vtec95Civic Vtec95Civic is offline
Is it the same on right and left turns? Does the clutch stick to the ground?
Where's the sound coming from?
Need more info, me thinks.
Old 02-14-2005, 08:43 PM
david-b's Avatar
Dave is THAT guy
Re: Car making New sound
Clutch is fine. I believe its on turns both ways. Sound seems to be coming from the engine compartment, hard to tell tho
75 Monte Carlo
Old 02-14-2005, 09:41 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Somethin kinda like what you describe happened to me on my oldsmobile cutlass supreme (no longer own). Ended up being the power steering pump. One day it just went out on me, and cost me $350 to replace. Check your power steering fluid and pump. Might be whats causin it.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 02-14-2005, 09:53 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
when it's in the shop, have the suspension and drivetrain checked over. that's most likely where the noise is coming from.
95 Talon TSI AWD
97 Eclipse GST
Old 02-15-2005, 10:59 AM
P_T P_T is offline
Sounds like cv joints to me. Relatively common for front wheel drive cars. Kinda odd that it's doing it on both sides at once though, usually one goes before the other, but once one goes, the other isn't far behind.
Old 02-15-2005, 11:06 AM
AngelOfNight 9's Avatar
AngelOfNight 9 AngelOfNight 9 is offline
Check your CV joint, wheel bearing being tight, sway bar Linkage, and balljoint. Also check your motor mounts, tires for a bulge & rims.
*91 TSI AWD*
