Old 02-14-2005, 08:15 PM
kazmaniandevil05 kazmaniandevil05 is offline
Send a message via AIM to kazmaniandevil05
Question Knocking Noise When Turning
Can somebody please help me!!!!
I own a 2000 GTP and i have this problem: sometimes when I turn, my car makes a knocking, popping noise in the front. I have recently discovered that it also happens when I start moving after the car kicks into gear when I change to drive or reverse. I have taken it in three times to the dealership because I am under extended warranty. They have replaced the axel hubs, replaced the tie rod boots, and inspected the CV joints. Does anybody have any idea what this could be????
Thanks in advance
Old 02-14-2005, 08:39 PM
stlwagon stlwagon is offline
Re: Knocking Noise When Turning
Possible lower engine mount failing. Try putting it in gear and torque-brake the car in drive and reverse. If the engine mount is going you may hear a clunk as the engine drops under load.
Let us know.
Old 02-14-2005, 08:43 PM
what do you mean "torque-brake the car in drive and reverse" ?
Old 02-14-2005, 08:46 PM
BIG-L's Avatar
BIG-L BIG-L is offline
put the car in gear,place your foot on the brake and give it some gas and try it in D and R gears around 2,000/2,500 RPM oops fixed that got push button happy
ClubGP Member 6530
Since 2001
Old 02-14-2005, 08:48 PM
Car in gear, e-brake applied and foot on brakes while applying gas. You want to put a load on the engine but keep the car from moving.
Old 02-14-2005, 08:50 PM
Probably want to avoid 25,000 rpms unless you want to orbit the earth!
Old 02-14-2005, 08:54 PM
ok i did that
when i put it in drive it didnt make a noise at all, but when I put it in reverse it did make a faint knoching noise but not as loud as normal, but nonetheless a noise.
So does this mean i should take it to the dealership and tell them its the lower engine mount failing?
Old 02-14-2005, 08:59 PM
It could still be going but if really bad you'd hear a noticeable clunk. Mine was really bad and was loud in drive and reverse.
Have a friend torque-brake the car while you stand in front (don't get run over). Watch the engine to see if it drops under load. If you see a significant drop, it may be worthwhile to have the mounts checked.
Old 02-14-2005, 09:00 PM
When you had the problem, did it affect your driving?(just wondering)
It doesnt affect mine
Old 02-14-2005, 09:08 PM
No. Just annoying everytime I'd accelerate from a stop. Thought it was my tranny at first. Actually when I replaced the upper and lower, my shifts improved dramatically as more engine torque was being directed to the drivetrain instead of moving the engine around.
FYI bottom mount was about a $275 job with my local mechanic (not Mr. Goodwrench). I did upper mounts myself. That's easy and cheap ($69 for poly mounts from 3800 performance).
Old 02-14-2005, 09:09 PM
yeah thank god im under warranty!!
Old 02-14-2005, 09:10 PM
ok well thanks a lot
i hope this fixes the problem
Old 02-14-2005, 09:11 PM
Good luck. If it's not the fix, let us know and we'll reattack.
Old 02-15-2005, 05:08 PM
tkhilliard's Avatar
tkhilliard tkhilliard is offline
my 02 gt clunked kinda like what kazman describes and turned out to be bad wheelbearing. the mechanics were surprised thats what it was.
just a thought for yall
Old 02-15-2005, 05:59 PM
NeilS NeilS is offline
Send a message via ICQ to NeilS Send a message via AIM to NeilS Send a message via Yahoo to NeilS
I had the same problem with my 99 GT and it also ended up being a wheel bearing; it was easy to tell because one of the bearings had more movement in it than the other one did. That had move of a constant click with each turn of a the wheels after it had been doing it for a while.
However, before that I had a clicking when turning, put a little grease on the back of the brake pad and it went away, haven't heard it since.
