View Poll Results: Which tires
BFG AT KO 10 71.43%
Bridgestone Dueler AT Revo 4 28.57%
Voters: 14. You may not vote on this poll
Old 02-14-2005, 06:57 PM
fureyj fureyj is offline
Send a message via AIM to fureyj Send a message via MSN to fureyj
Question Which Tires to get
Its coming time to replace my tires on a 2000 Silverado Z71. It has the stock 245/75/16's on it, but I wanna go to a bigger size. I'm debating between 265/75/16 or the what seems to be popular size on this forum of 255/85/16. What are the benefits and disadvantages of both. Now for the tires them selves I can't decide between the BFG AT KO's or the Bridgestone Dueler AT Revo's. Any and all help would be appreciated. thank you.
2000 Silverado LS Z71
Current Stuff:
Sylvania Silverstar low beams and fog lights
Aftermarket XM radio
Rhino Linings
K&N Filter
Stuff to Come:
CB radio
True Flow air intake
Silverstar high beams and 4 headlight mod
BFG tires
Rancho 4" lift with adjustable shocks
LED lights.
Old 02-14-2005, 07:24 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Which Tires to get
One of the benifits of going to the 255/85/16 is the added ground clearance. A couple of disadvantages are the loss in get up and go and most likely a decrease in fuel mileage because of the size difference ESPECIALLY from a 245/75/16. I would check into what gears you have before you get such a tall tire as the 255/85/16 is (33.3" tall when new........well the BFG MT is anyhow.)
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 02-15-2005, 01:49 AM
buttnekked buttnekked is offline
had the revo's 265/75 not overly impressed with traction in mud but good ride and very quiet.
Old 02-15-2005, 08:02 AM
Jake795's Avatar
Jake795 Jake795 is offline
I have the 255/85r16 in the Mud Brute. I looked up the specs on these and they are about a inch and a half taller than the 265/75 Brutes. I wanted to get as much clearance as i could so that's why i went tall and skinny. I had to do just a little bit of front fenderwell trimming on the passenger side only to make them fit without any lift. BTW the Brutes are excellent in the mud and muck.
Jake
Old 02-16-2005, 01:49 AM
grego12r grego12r is offline
i went for my 2000 silv from 245/75/16 to 265/75/16 whit nitto gaplers a/t
from discount tire direct .com they are 110.00 $ a pice whit free shipping
and they are very good in snow and mut and the price is ok one thing more they are made in japan
BfG sucks same whit brigt stons dulers
Old 02-16-2005, 07:23 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Since when does BFG suck? And bridgestone duelers depending on what kind you get (A/T, M/T) are very good tires as well. I worked selling/mounting/fixing tires for 10 years... You definately get what you pay for.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 02-16-2005, 10:10 AM
I wasn't crazy about my revo's but one nice thing; they have a thick sidewall and hold up to abuse well. I lived in a new subdivision and gouged a sidewall with a piece of steel and had no problems.
Old 02-16-2005, 04:51 PM
sierra99 sierra99 is offline
Michelin LTX 265/70/16 these are great tires. i have about 60,000 miles on thes and still have 1/2 the tread left. you get order them from sam's club for about 160.00 but.....you spend 9.99 per tire to balance mount and road hazzard.....but the trick is that if they don't have your tires done in 1 hr or less then you get back the 9.99 per tire. i dropped my truck off on a saturday at noon.... let's just say thaT i DIDN'T HAVE TO PAY THE 9.99 PER TIRE.
Old 02-18-2005, 10:37 AM
rrousou rrousou is offline
Stay away from bridgestone tires. I had a set a few years ago and the sidewalls bulged out after they were a year old. Took them to the dealer and they refused to warrant them. Complained to Bridgestone direct and they said it was the dealers problem. I ended up replacing them and paying the cost myself. Needlsess to say it wasn't Bridgestone.
Old 02-18-2005, 02:01 PM
clauritzen clauritzen is offline
I have a set of Bridgestone Revo's 265/75/16 and love them. The traction is good and the ride is smooth and quiet. You should check out www.tirerack.com and research the tires there. They both get good reports from users, but depending on what you do, there are a lot of people that like the Revo's better.
Old 02-18-2005, 11:22 PM
J-Ri's Avatar
J-Ri J-Ri is offline
What do you want to do with the truck? On road, off road, towing/hauling?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-19-2005, 05:23 PM
sorry i havent responded sooner the computer is acting up. I'm mainly gonna be onroad with some light offroading. I'm in NJ so I need a tire thats pretty good in the snow. I do some light towing 2 ATV's so I dont need a heavy duty tire.
Current Stuff:
Rhino Linings
K&N Filter
Stuff to Come:
CB radio
BFG tires
LED lights.
Old 04-11-2005, 11:23 PM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
go with bridgestone...i would say bfgs if u were going to be doin more offroad
'99 Silverado 4 x 4
bunch of goodies
Old 04-14-2005, 12:43 PM
Bungee's Avatar
Bungee Bungee is offline
Re: Re: Which Tires to get
Bridgestones Duelers are a decent tire for the functions you outlined. I had them as my last set. I have similar uses as you (less snow here in San Diego, tho ). But if you are not married to the whole BFG/Bridgestone idea, you might consider the Cooper Discoverer ATR ... I'm running these now ... more aggressive tread, yet extremely quiet on the freeway ... great in snow and maderate offroad conditions ... they wear slow ... and are well-priced--less expensive than the Duelers in my case. Overall, a better value than the Bridgestones IMO.
Mods:
Aluminum Billet Grill
Pine Tree (TM) Air Freshener
Armor-All (TM) Moistened Dash
Old 04-14-2005, 11:00 PM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
REVO's kick ass. I've never done a side by side of these two tires obviously but I'll put my money on the Bridgestone's, not only because I own them but before we bought them I did a lot of research. In the mud they throw that shit everywhere but they do what they're suppose to. Didn't get to test them out in snow much but they were good in a couple inches and always got me through some big piles. The performance in rain exceeds any other A/T tire out there. I can't say that braking is just as good as on a dry road, but it's damn close. Just becareful if your a fast driver on a gravel road, these fuckers throw rocks with a habit. My dad now has these tires too, he had Goodyear Wrangler AT/S on before that and you wouldn't believe how much of a difference the Bridgestones' made, not just in traction everywhere but the ride quality is much better, of course I've never had anything good to say about Goodyear. I can't say much about the BFG's but a few friends do have them and they're definately not a bad tire.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
