| Off-Topic Talk about anything other than cars. |
boost leak probs??
Ok, so under hard acceleration, when my car hits boost (about 3k), its not a smooth pull, its all jerky and stuttery. I searched around and went out to my car and checked all the clamps on my intercooler hoses, BOV return hose etc., and checked my vacum lines. THey were all fine. What else could be causing this?
'95 Eclipse GS-T 5spd.---totaled..she was a bitch anyways '06 Chevy Cobalt LS, Auto---sold to my sister. The most bland, numb-feeling car I've ever driven. Oddly torquey though. |
Re: boost leak probs??
bad plugs/wires. build a boost leak tester like on VFAQ.com and check that then pull a plug and check if its old or crappy looking
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
i had that problem...had a big boost leak in the LICP...checking hoses, clamps etc won't do it...there could be a hole/slice in a hose somewhere....use a leak tester to check. i fixed my boost leak and it runs perfect again
ok, ill build one tomarrow when I get my car back. Getting new tires, and alligned.
Exactly. You can't always "see" boost leaks. You have to build the tester and listen and use soapy water, etc.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
