Old 02-14-2005, 05:05 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
turndowns...
over the weekend i took off the tailpipes on my 87 GT because the speed bumps where i live are too tall and it scrapes the shit out of the mufflers, so i raised the mufflers enough to not scrape. i drove around with the mufflers ( 2 chamber flowmaster 40 series) to find out that its too loud without the tailpipes. i was just wondering if turndowns would quiet it a little? also where to find ones for a 2 1/2 id muffler and how long of one to get. will it give the exhaust a different sound, baffel, or pulse? i don't feel like getting any tickets so i got to get them soon. any help would be great. thanks
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 02-14-2005, 05:42 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Turndowns would only make it worse cause it would echo off the ground even more direct. Are the mufflers hitting or the tail pipes?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-14-2005, 05:51 PM
Re: turndowns...
the mufflers are hitting the speed bumps
Old 02-14-2005, 05:56 PM
WoW, you've got some big speed bumps by you. I dont really know what to tell you. Is it lowered?
Old 02-14-2005, 06:03 PM
SMOKEY818 SMOKEY818 is offline
Re: turndowns...
Actually if you get down pipes it will quiet your car, yeah i have the same problem with my maro, who in the hell invented those big ass speed bumps i wish i could beat the crap out of them,
89 Camaro with lt1/t56/headers,borla exhaust,ac delete, march pulleys, slp CAI,3.73 gears,msd ignition,port & polished heads, reprogrammed pc, free mods, hotchkis suspension,sub-frame conn & weight reduction.
Old 02-14-2005, 06:05 PM
Re: turndowns...
yeah the speed bumps are really tall. and no the cars not loward its at stock height. i'm not sure what to do.
Old 02-14-2005, 06:15 PM
Re: turndowns...
what do u mean by down pipe it and the guy put them so tall because they have been having problems with speeding with kids.
Old 02-14-2005, 09:47 PM
Re: turndowns...
would some sort of exhaust tip with a resonator work or would that make it sound funny or create more back pressure?
