Old 02-14-2005, 06:03 PM
DuffGTP06 DuffGTP06 is offline
Send a message via AIM to DuffGTP06
u-bend delete
I don't wanna sound dumb or anything, but I gotta know, what is a u-bend delete exactly, how much $ will it cost me and what kind of HP does it add. Everyone else seems to be doing it as one of there first performance upgrades, so I think I should probably be doing it as soon as I can.
Old 02-14-2005, 06:23 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Here is a nice write up on it !
By Jim Wierzbicki on August 15, 2002... Thanks Jim!
For quite some time, there has been many claims and conjectures about the performance impact from removing the factory U-Bend in the exhaust system on the GM 3800 Liter V6 (Naturally Aspirated L36 and Supercharged L67). For those who are not familiar with the U-Bend, it is a bend that GM designed into the exhaust pipe exiting the catalytic converter. (See Figure 1) The purpose of the bend it to permit the O2 sensor downstream of the catalytic converter to be mounted in a position that would provide the maximum protection from possible road hazard damage. The downside of this configuration is that the bend poses a moderate restriction to exhaust flow. A popular modification is to replace the U-Bend with a straight pipe that contains a fitting for the O2 sensor. The sensor is typically mounted in a horizontal position to provide accessibility and keep it out of harms way as much as possible.
To help resolve these claims and conjectures, I obtained a test vehicle (Pontiac Grand Prix GT, L36 engine) that had a complete factory exhaust system. This factory exhaust system included cast iron exhaust manifolds, catalytic converter in the down pipe, U-Bend, resonator and dual rear mufflers. The testing would involve replacement of the U-Bend with a straight pipe that would include a port for mounting the post-cat O2 sensor.
Prior to the installation, I collected performance data to baseline the car’s performance. After this data was collected,
I pulled down the down pipe with the U-Bend and replaced the bend with a straight pipe.
Once this modification was competed, I repeated the performance tests. The weather conditions for the day were warm and humid. During the testing with the U-Bend, the temperature was 83ºF, Humidity of 78% and a barometer of 30.02 "of Hg. The engine was thoroughly heat soaked and running 192ºF by the PCM’s Engine Coolant Temperature values. A total of 12 passes were used to collect all the performance data, with 4 replications for any one parameter. The results for replicated runs of each parameter were averaged together in the final analysis. The test conditions with the U-Bend removed were nearly identical, the temperature held at 83ºF, Humidity of 83% and a barometer of 29.95 "of Hg. The GT was running on 93 octane, has 8,000 miles on the engine.
As can be seen in the charts, the gains in peak HP and Torque were ~5.0 HP and 2.9 ft-lbs respectively. Also noteworthy is the torque and resulting HP curves were benefited throughout the entire RPM range. This data does not support many beliefs that removing the U-Bend will improve the upper RPM power & torque and sacrifice low end power & torque. A 1% increase in volumetric efficiency and total volumetric flow rate was also seen, which corroborates the increase in HP and Torque. Also interesting is the slight increase in overall spark advance through reduction in Knock Retard. About 2º of advance was picked up. This increase in spark advance and the slight improvement in volumetric air flow is what produce the small but significant performance gains. My conclusion is this modification has benefits all round.
While these results were obtained on a relatively stock GT, they are representative of the gains to be made on more significantly modified L36 engines as well as L67 engines. The more modified the L36, the more restrictive the U-Bend becomes and the more it constricts power increases. I would estimate proportional increase would be observed on an L67 supercharged engine. If this is the case, the U-Bend replacement on an L67 engine would extrapolate to a gain of 6 Peak HP and 3.5 ft-lbs Peak Torque. While these gains are not huge, they are significant and provide an edge over cars still running with the U-Bend in place.
Good luck with seeing the chart !
ClubGP Member 6530
Since 2001
Old 02-14-2005, 09:25 PM
stlwagon stlwagon is offline
Re: u-bend delete
U-bend delete is definitely one of your first mods especially if considering a smaller pulley. Need to increase airflow in and out to keep KR down. I'd recommend ubend, CAI, and pulley in that order.
Larry- that's one heck of a write-up. You sure know where to find 'em.
Old 02-14-2005, 11:39 PM
Re: u-bend delete
Larry, has anyone ever told you you're the greatest man alive? Thats awesome, thanks.
Thanks too stlwagon
Old 02-15-2005, 12:27 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: u-bend delete
Been trying to get him to quite his job and write a book. I want the one that you have to color in the lines. But, he wants one with words.
Thanks too stlwagon
Old 02-15-2005, 06:33 PM
Re: Re: Re: u-bend delete
Some coloring books have words.....
Old 02-16-2005, 08:56 AM
strotma strotma is offline
Question U-Bend
About the U-Bend delete---
The muffler shop Tech said your exhaust flow is only as good as your smallest diameter pipe.
With stock mufflers on it he claims they have 1 ¾” pipe running through the inside of the muffler.
Which means to me, if you delete the U-Bend you still have another bottleneck at the end of the exhaust system.
Old 02-16-2005, 11:32 AM
BIG-L's Avatar
Re: U-Bend
The exhaust shop I use, told me im reading to much,that there is no difference between a stock catalytic converter or a high flow catalytic converter Just gota take there words with a grain of salt.They seem to know more then a dyno test
~Larry~
ClubGP Member 6530
Since 2001
Old 02-17-2005, 06:53 PM
Re: u-bend delete
jeez Larry. . . . .what don't you know?
