Old 02-14-2005, 05:09 PM
riccbhard riccbhard is offline
A/C Blowing Hot Air
Our 1998 Blazer LT 4x4 (V6) - is blowing hot air from the vents, not changing with switch position (computer climate control). I have been told that there is a part missing off of the accumulator. I have the following pictures that I took of the accumulator.
I was wondering what parts are missing (if any) and how to fix it.
Picture 1:
Picture 2:
Thanks in Advance!
Old 02-14-2005, 05:47 PM
DaveLance's Avatar
DaveLance DaveLance is offline
Re: A/C Blowing Hot Air
That's the low pressure service port. All that is missing is the cap.
Old 02-14-2005, 07:57 PM
Thanks. Do you know where I could get the cap?
Old 02-14-2005, 08:22 PM
ricksza's Avatar
ricksza ricksza is offline
The cap won't restore your cold air. You will need to have the freon checked, may have a leak.
Old 02-14-2005, 10:52 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Picture 1:
Picture 2:
Thanks in Advance!
So you are saying you can't adjust where the air is blowing right?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-15-2005, 03:33 PM
I can adjust air flow, but all I am getting is hot air.
Old 02-15-2005, 03:37 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: A/C Blowing Hot Air
As stated above, get the freon checked. Even with the A/C off, your compressor will run when you turn on your defrosters. I had a compressor freeze up because of low freon, which also contains an oil additive to lube the compressor. With a serpentine belt, you don't want to freeze up your compressor, it will destroy a belt.
Old 02-15-2005, 09:23 PM
Trail Blazin96 Trail Blazin96 is offline
Send a message via Yahoo to Trail Blazin96
Look at the compressor if there is an oily look then you have a leak and you will more than likely need to replace the compressor! you will know that it is leaking just by looking at it you will see the dirt built up on the spots where the peg oil is coming out! if you can take a picture of the compressor different angles, unless you find where it is leaking, i do agree it is leaking somewhere, it is just a matter of finding it, check the hoses carefully.
Old 02-15-2005, 09:27 PM
ricksza's Avatar
The mid-body seals on the compressor are common leak points. If it's wet under the compressor, it's bad. Will need to partial charge to test the rest of the system.
Old 02-16-2005, 04:40 PM
Thanks for all of your help. I will try these suggestions when I get time.
