Go Back   Automotive Forums Car Chat > MG > MGB
Old 02-14-2005, 03:25 PM
edothas edothas is offline
alternator capacites
I have a 72 mgb, stock except for an electric fan; I want to add a sound system, since it is currently devoid of one, and may have been stock without (??). Without undue rambling, I hope, (er..) how much current can these alternators put out? can i just drop 4 speakers and a deck into it without worrying, or do I need to check the alternator against the system draw?
Old 03-17-2005, 04:11 PM
Flash75 Flash75 is offline
AF - Advisor
Re: alternator capacites
The original alternator ACR16 has a maximum output of 34 amps. Low rpms and lots of night driving the output is less. I assume the electric fan is a back up for the engine driven fan. If you don't want a high powered stereo the alternator output may be enough for you needs if you don't do lots of night driving.
Clifton
Old 05-14-2005, 12:04 PM
nutman79 nutman79 is offline
go with the saturn conversion.110 amp compared to 34 a no brainer.use a 90-91 saturn alt works great. you will have to research this out and be handy with you hands.some modication are needed .go to this site use there search engine to find the info you need.
http://www.mgbexperience.com/
