Old 02-14-2005, 01:18 PM
Sp3cops70's Avatar
Sp3cops70 Sp3cops70 is offline
Send a message via AIM to Sp3cops70 Send a message via MSN to Sp3cops70 Send a message via Yahoo to Sp3cops70
What does this mean???
Originally Posted by adblink182
what could I do to the engine for about $500 so if I pulled up to an identical grand prix GT I would have the edge?
Intense PCM,CAI and U-Bend delete
^^^^^^^^^^^^^^^^^^^^^ What does that stand for...PCM, CAI and U-Bend??
Old 02-14-2005, 01:38 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Re: What does this mean???
We use lots of different abbreviations on the message forum to save time typing commonly used phrases and names. Some of these are…
Car parts:
CAI – Cold Air Intake
DIC – Driver’s information center (The readout above the center AC vents)
DP – Downpipe
FWI – Fenderwell Intake
KR – Knock Retard
NA or N/A– Naturally Aspirated (no supercharger or turbocharger)
PCM – Powertrain Control Module (The car’s computer)
SC – Supercharger
U-bend delete is a part of the exhaust that is restrictive and houses the down stream O2 that monitors the cat.
On the factory exhaust for your car, GM decided they wanted the O2 Sensor mounted vertically which resulted in what's been termed the U-Bend. This restrictive section of pipe causes added backpressure resulting in power loss. Modifying your car with a different intake system and/or smaller pulley only makes this restriction worse. Free up this restriction with our U-Bend replacement. Many owners have this piece fabricated and installed at a local exhaust shop for around $50-$75 or so. If you're having a hard time finding someone to do this, or you would just rather buy it pre made and have it installed, we've got it here for you. Because it requires welding to the catalytic converter, you will need to have it installed.
ClubGP Member 6530
Since 2001
Old 02-14-2005, 01:42 PM
Sp3cops70's Avatar
Re: Re: What does this mean???
Very informative...thanks alot.
Old 04-01-2005, 10:04 PM
always bet on blck always bet on blck is offline
Send a message via MSN to always bet on blck
Question catalyc converter
i had my cat taken out the other day was this a good thing or a bad thing.....
Old 04-04-2005, 08:31 AM
carnutcass's Avatar
carnutcass carnutcass is offline
Bad if you live in a place that does emissions testing. In the St. Louis area, the are supposed to do a visual check to make sure a cat is in place.
Old 04-04-2005, 09:12 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Nice sig.
Florida doesn't have that anymore. But with the old farts hitting every car on the road, who needs it.
Old 04-05-2005, 04:18 PM
i think i'm ok i live in calgary alberta canada i dont know what kind of checks they do on stuff like that but i noticed a difference in my gp tho....how much actual horspower does that modification add and could i get even more by removing the resonater as well?
Old 04-06-2005, 09:38 AM
AKWE-gt AKWE-gt is offline
if they do emission tests like they do here in ontario your most likely going to fail. canada is on board for the Kyoto Act and i'm pretty sure that they'll be testing there so it would be a good idea to shop around for a hi-flow cat before they sting you at the testing shop.
[size=5]
