Old 02-14-2005, 01:00 PM
stngray stngray is offline
a/c and electric issue
'98 Cherokee Limited, has two problems the a/c has started blowing hot air. went to jiffy lube and had all liquids checked and replaced still getting hot air
my airbag and check engine lights come on intermittantly. the gauges all go off and then come on (they have a mind of their own). fuses all look ok
what are my options? is the one issue being caused by another?
Old 02-15-2005, 06:51 AM
wild13 wild13 is offline
first your ac is 99percent your evap coil this is very hard and exp to replace it takes 7 to 9 hrs as you have to remove the whole dash aprox 900$ i am a mech and have done several as 4 the lights try dis the batt for a few min and clear the comp good luck
Old 02-15-2005, 12:03 PM
Re: a/c and electric issue
thanks will try the battery tonight.
