Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-14-2005, 12:37 PM
roxxx roxxx is offline
Question Axle nut question for wheel bearings
I have to change the wheel bearing. First time since I got the car. The brakes are always going bed but oh well.
It looks like the axle nut is four thin nuts wrapped in a piece of flat steel.
How do you get it off:
1) unwrap the flat steel and take them off individually, or
2) use a larger socket and take them all off as one unit.
Please help me
Thanks
Old 02-14-2005, 09:56 PM
jr6078 jr6078 is offline
I don't know what year your Alero is, but the book I have for 1999 / 2000 models says that you just break the nut loose with a wrench. Nothing about removing any outer layers.
Good luck.
Old 03-06-2005, 07:26 PM
fergo99 fergo99 is offline
I changed the bearings on my 01 Alero and the nut should come off as one unit.
Old 03-07-2005, 01:37 PM
DamienZ28's Avatar
DamienZ28 DamienZ28 is offline
Re: Axle nut question for wheel bearings
Make sure NOT to unwrap or cut that nut! The sheet metal holds the 2 nuts just right to make them lock on the threads! Get the right sized socket and if your not using a impact get ready for a sore arm.
http://www.fiawtcc.com/
2006 BMW 330i| 2009 Mercury Mariner Premier
Old 04-25-2005, 10:32 AM
jaimepop jaimepop is offline
Wheel Bearing Replacement
I am about to replace a wheel bearing on my 2001 Alero also. I don't yet have a repair manual for this car, though. Can anyone post the specified axle nut torque, please? Also, what is the recommended torque for the 3 bolts that attach the hub assembly to the steering knuckle? Thanks.
Old 04-25-2005, 03:30 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Jaime, I PM'ed you a great link with everything you need to know. Good luck, and welcome to the forum.
Roxx, I'll send you the same link too. It's a link I can't display on here because it's for another automotive forum - so I would be violating AF rules - which I is why I have to send it via PM. If anyone else wants it, let me know.
Old 04-26-2005, 11:51 AM
Smile Thanks very much
Ridenour,
Thanks very much for that great link. It came in very handy. The hub is replaced now and it sounds much better and the dash lights are no longer on.
Thanks again,
Jaime
Old 04-26-2005, 02:01 PM
Ridenour's Avatar
GranddAmnit
No problem Jaime - welcome to the forum.
If anyone else wants that link, be sure to let me know.
Old 01-28-2006, 09:05 PM
ml258 ml258 is offline
I could use that link [email protected]
Old 01-28-2006, 11:22 PM
JTrujillo86 JTrujillo86 is offline
Me too! I'd really appreciate it.
You can PM me or e-mail it to [email protected]
Thanks,
Jeremy
Old 01-30-2006, 03:50 AM
mcrosby mcrosby is offline
Ridenour,
I could use that link also.
Thank you,
Mike email: [email protected]
Old 05-20-2006, 02:08 PM
jimbmw jimbmw is offline
Okay, add me to the list of needing the link for replacing the wheel bearings, thanks. [email protected]
Old 02-02-2007, 02:29 PM
gwdew gwdew is offline
I'd like the link too [email protected]
Old 02-02-2007, 02:56 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry guys this is an old thread. Therefore, I've closed the thread. For the link, PM the member that suggested it.
BTW - Exercise caution on the axle nut torque value. For '99-'04 Aleros to include Grand Am there are two different axle nut torque values depending on which axle nut you have. There are two designs. 1st and 2nd. The first design axle nut is a PAC type nut painted black so the torque value is 284 ft-lbs. The second design axle nut which is solid gray is torqued to 173 ft-lbs. If not adhered to you will be replacing hubs all over again in a short period of time.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
