Old 02-14-2005, 11:56 AM
volkerc's Avatar
volkerc volkerc is offline
91 PA,Who knows how to remove instrument cluster??
Who can help me with this?
I 'm not sure how to remove the instrument cluster on my 91 Park.I know how to remove the plastic woodgrain, but that is it, don't want to brake anything, and need to replace a light bulb in there....and I can't get to it from behind the dash...so it seems...
Old 02-14-2005, 02:51 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: 91 PA,Who knows how to remove instrument cluster??
After the woodgrain is off, you need to remove the black trim. First, pop out the air vents. do this by turning them to one side, and gently yet forcefully pulling them out. Thes give access to one screw per vent(do not drop the screws) and remove the screws at the base of the trim(previously covered by woodgrain). You'll need to move the gear selector to a low forard gear to get the black trim off. You should now have access to the instrument cluster.
Old 02-14-2005, 03:00 PM
volkerc's Avatar
Re: Re: 91 PA,Who knows how to remove instrument cluster??
thanks tman,i'll try this.
