Old 02-14-2005, 11:14 AM
sajr74 sajr74 is offline
Send a message via AIM to sajr74 Send a message via Yahoo to sajr74
no brakelights no dashlights 92 f150
ok now i have replaced flashers,fuses,bulbs multishitch,dimmershitch,brakeshitch..
and removed trailer pigtail and checked pins before snapping it back in
and still i have no brakelights or dashlights
but my hazzards,turnsignals,parkinglights/runninglights.headlights all work fine...
what else is there to check??
btw i bought a test light and tested the brake wire form where it comes throught the fire wall and its dead no power when pushing the brake pedel so the problem is clearly under the dash or is it??
i all so tested the brake switch the green wire with the red stripe is hot
but when i hold down the brake pedel to test the other wire the the green one its dead i also tryed to jump the to wires but instead of lighting up the brake light it blows the fuse i have replaced the brake shitch two times...did i miss something??/ please let me know.
Old 02-14-2005, 03:28 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: no brakelights no dashlights 92 f150
Are the turn/hazard lights seperate from the brake lights? Pull the brake lights out and see if the fuse still blows when you bypass the switch.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
