Old 02-14-2005, 10:42 AM
greginportland greginportland is offline
Question Smell of Match when starting
After replacing:
Fuel FIlter, TPS, EGR, CPI & Nut Kit, Dist Cap & Pluts & Wires,
and an Oil Change -
4.3 runs great!
When I start it it has a smell of a match - sulfur I think. The smell only lasts for a few seconds and fades away.
Anything to be concerned about? Or am I acting like a mother worried about her baby coughin?
I did clean the intake plenum the best I could w/ gasket cleaner, and turpentine w/ a rag, it wasn't shiny when I was through, but got any carbon crumbs and thick layers out.
Old 02-14-2005, 11:22 AM
mrfirebird mrfirebird is offline
sulphur smell sounds like egr valve, maybe moved a piece of carbon and needs recleaned.
Old 02-14-2005, 12:21 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Smell of Match when starting
Originally Posted by greginportland
After replacing:
and an Oil Change -
4.3 runs great!
Usually, the sulphur smell means a bad Catalytic Converter.
Old 02-14-2005, 09:33 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
yip, your cat is poisoned.
Time to swap it out.
It is usually destroyed by the bad cpi injector.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-15-2005, 10:38 AM
Re: Re: Smell of Match when starting
thanks, i'll look into the cheapest fix $$$, should be pretty easy to do for a layman.
I guess I probably shouldn't bother trying to do the Cali. smog test until I get that fixed. Any Cali folk that can tell me if a Cat. Converter is a Cat. Converter or if I need to be picky about what brand or emission rating (if there is such a rating)?
greg
Old 02-15-2005, 10:46 AM
Big Tall Dumb Ass
Re: Re: Re: Smell of Match when starting
greg
Check with the Califonia Dept of Air Quality before you buy anything. In Arizona there are very specific manufacturers and even specific model numbers of Cats that are approved for use. If you replace with Joe Blow's brand of Cat, you're toast.
Old 02-15-2005, 02:44 PM
BlazerLT's Avatar
AF -Advisor
greg
Get a universal CAT and have it installed instead of the prefit for our trucks
MUCH cheaper.
