Old 02-14-2005, 10:35 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Angry d16 oil pan gasket
It seems like my oil pan gasket is springing a leak. Is this a big job of replacing it? Some of the bolts look like they're a pain to get to. I'll have to remove the downpipe on my header (2 piece DC) but please tell me I won't have to unbolt the tranny...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-14-2005, 10:46 AM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: d16 oil pan gasket
Mines is going to have to have the same thing done. Let me know how it goes
Old 02-14-2005, 10:50 AM
5gcivic's Avatar
5gcivic 5gcivic is offline
I just replaced mine, you will have to remove the lower piece of the header and the flywheel dust cover and it should come right off, you will need a long extension tho. Good luck
Old 02-14-2005, 10:53 AM
5gcivic's Avatar
oh yea, dont forget to but some rtv at all the corners. I didnt do that and the leak was worse than the old gasket so I had to pull the pan again.
Old 02-14-2005, 10:58 AM
Re: Re: d16 oil pan gasket
Thanks for the info.
2010 Honda CR-V EX
Old 02-14-2005, 11:07 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
if it leaks at all corners then you installed it wrong. i put mine on with no sealant and its not leaking
Team Lonely Drivers
Old 02-14-2005, 11:40 AM
It's stock. I'll switch it out next oil change...
2010 Honda CR-V EX
Old 02-15-2005, 12:32 AM
fooshman3 fooshman3 is offline
Send a message via AIM to fooshman3
i just ordered a new pan for mine and i hope it gets here this week...someone let me kno how long its gonna take to do and what all i have to do cuz ill have to come home from college to do it but im happy cuz i havent worked on her for a while
91 CRX Si
Chrome projector headlights, Clear corners, JDM style wing, GTS Tuner Short ram intake, 5Zigen Catback Exhaust, Random Techonology Test Pipe, Neuspeed Short Shifter, Neuspeed lowering springs, Tokico Gas Shocks, Bosch Spark Plugs, Bosch wires, 15" 04 Civic Si wheels, Sony F7700 CD player, Kenwood 6.5" speakers, JBL 12" Subs, SPL 1200W amp
Waiting to go on: DC sports cam gear
Need to buy: oil pan, maybe a mini me swap
Old 02-15-2005, 12:53 AM
Hybrid1990crx's Avatar
jeez must be a trend! I have to replace the oil pan on the b16 whenever I get around to putting it in my crx. Shouldnt be that hard at all to do it. Im just waiting on my rad, pan, clutch, and flywheel to come and the motor goes in.
Old 02-15-2005, 01:42 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
like they said, take the downpipe off, take the dust cover off, and unbolt the oil pan.
and definitely get a tube of hondabond, or comparible RTV sealant. you will need to put it on both ends of oilpan, right where it curves down for the two endcaps that the crank sit in. that area is about 3 or 4 inches of space with no bolts to hold a good seal, so if you dont put the sealant there, eventually you will get a leak. as an extra precaution, i put sealant on each of the small bumps that flank every bolt hole. it helps hold the gasket in place while you put the pan back on, and it also gives a better seal.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 02-15-2005, 07:53 AM
Okay, I've got a print out of the diagram from the manual...
http://www.binghamtonlife.com/manual...ges/91-7-4.jpg
It doesn't look too difficult... some of the bolts are a pain in the ass to get to, but I was under my car up on a scissor jack and low jack in the grass inspecting it. When I swap out the gasket, I'll be in a garage with the car sitting much higher up in the air... LOL.
So basically I put the RTV sealant on the gasket, align the gasket to the pan and reinstall. I guess I can clean the pan out while I'm at it. Sorry if I sound stupid... first pan gasket replacement...
2010 Honda CR-V EX
Old 02-15-2005, 11:44 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
yes, downpipe comes off, takes a few minutes to change it, and do NOT use any gasket sealer on the gasket, it is ment for cork/paper only, if u use it with rubber it will leak even worse
Old 02-15-2005, 05:59 PM
5gcivic's Avatar
Ok, well for future reference dont ever get under a car with a sissor jack on grass. Its bad enough getting under a car sissor jacked up on concrete. Unless you have a death wish, use jack stands next time. Not tryin to be an asshole just tryin to save some pain or lives. But anyways, good luck gettin that done.
Old 02-15-2005, 11:08 PM
EF You's Avatar
EF Life Giver
no liquid gasket eh?
like i said before, follow my instructions and you wont go wrong. and for 1phatCX, add one step to it, insert foot in mouth and be quiet
Old 02-15-2005, 11:29 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
for 4 dr sedans arent you suposed to remove some kind of cross member to remove that oil pan?
