Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-14-2005, 09:22 AM
Preppy Preppy is offline
Rattling in driver door
I have a rattling in my driver door but it only rattles when i am slowing down in 2nd gear or first or if i am in nutural rolling up to a stop light on something. If i press aginist the door it will stop. Anyone know how to take the door panel off so i can get to it, or what it would be? There is also a clicking sound that happens from time to time when i slow down in 2nd or first gear that sounds like it is coming from the dash board in front of the passenger side. So far my solution has been installing speakers and a sub then just turning it up louder. Anyone got a better solution?
Old 02-14-2005, 12:32 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Rattling in driver door
year/model?
power windows or crank?
Old 02-23-2005, 10:25 AM
russm313 russm313 is offline
Re: Re: Rattling in driver door
I also have this same problem. I have a 1994 SL1 with manual windows. Any help would be appreciated.
Russ
Old 02-23-2005, 05:56 PM
bmwilson's Avatar
bmwilson bmwilson is offline
Send a message via Yahoo to bmwilson
easy not likely route 1) tighten all screws, bolts ect. and try your luck . Step 2) remove the door pad and look for visible debis in the bottom of the door, if not yet found then step 3) smack the door acordingly until sound is located. This process works equally for most any vehicle, make, model with either manual or power windows. Good Luck
