Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-14-2005, 08:29 AM
b7100 b7100 is offline
What is tbc circuit? Battery draw
I'm having a dead battery every 2 days in my '99 s10 truck. I've traced it to a fused circuit labeled tbc. An amp draw of about .63 amps is indicated between the lugs where the fuse plugs in. With the fuse pulled the door ajar alarm and the interior lights are off. Does anyone know what tbc is? With the door closed and all lights off I'm still having a .63 anp draw. There is no glove box light or under the hood light. What else in this tbc circuit could cause a draw of .63 amps. The radio circuit draws .1 amp. So I have a total draw of about 3/4 of an amp.
Old 02-15-2005, 02:56 PM
Cam1959 Cam1959 is offline
Re: What is tbc circuit? Battery draw
well, not sure but i'll take a poke at it since no one else has.
i see no fuse marked tbc in wiring diagrams in haynes book. but mine covers 82 - 93.
could it be ***** brake control. as in anitlock brakes ? maybe short in wires to or at wheels ?
Old 02-15-2005, 06:54 PM
Thanks for the reply. When I pull the fuse the interior lights and the door alarm go off. So I don't think the antibreak would be on that circuit, but it could be. I noticed when I shut the motor off the dome light dimms a little. I think I read that that could mean a bad diode in the alternator. Thats the next thing I'm going to check. As it is now every other day I just start it up and run it around the block.
Old 02-16-2005, 09:52 PM
Fireplug Fireplug is offline
Cant think of the entire name But its for the body control computer
Old 02-17-2005, 06:59 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Have you had the battery itself tested? Could have a couple of bad plates. (Just a thought)
Old 07-21-2006, 10:34 PM
DoctorP DoctorP is offline
Did you ever figure this problem out? I am having the same issue with my 99 S-10 right now.
Old 07-24-2006, 02:37 PM
BLAZERBOY69 BLAZERBOY69 is offline
TBC is Throttle Body Control. chek for a loose wire around the fuel injectors
Old 11-04-2006, 01:35 PM
ridesideways ridesideways is offline
Question Re: What is tbc circuit? Battery draw
i have the same problem. 1999 s-10 blazer. battery goes dead in 2 days. i put a ammeter on the battery and it draws 350ma (after everything goes into sleep mode).
i pull the TBC fuse (truck body computer) and the draw goes away (it drops to about 18ma, which is normal).
i replaced the battery yesterday with a brand new one-- still have the same problem.
did anyone every solve this problem? it sounds like it's something that happens frequently.
thanks!
Old 11-04-2006, 03:41 PM
maxwedge maxwedge is offline
A990 racer
I'd suggest you start a new thread here, this is way too old.
Closed Thread
