Old 02-14-2005, 07:44 AM
hobo1261 hobo1261 is offline
'98 Cavalier DRL Problems
My daughter's '98 cavalier is having problems with the day time running lights and low beam headlights. First, the right front low beam would not work but the lamp was ok. Ran jumper wire to left low beam light (dark blue wire) and everything worked fine for a month. Now, Day Time Running lights and low beams do not work at all. High beams are ok. DRL relay is ok. How do I troubleshoot the ouput of the DRL control module and where is it located?
Old 02-15-2005, 10:14 AM
EnjukuRacing240sx EnjukuRacing240sx is offline
Re: '98 Cavalier DRL Problems
its in the guage clutster itself... replace that everything should be fine. if not then re-check all fuses
Old 03-25-2005, 09:40 PM
Governor Governor is offline
Re: Re: '98 Cavalier DRL Problems
My daughters 99 has the exact same problem..her DRL relay is in the fuse box..I replaced it and it did not help..I also jumped out the Headlight switch still no low beams or daytime lights...short in the wiring somewhere I guess...
Old 03-26-2005, 09:24 PM
I fixed my daughters..yours prob same..It is a broken wire in the front harness under the battery pan..you will have fun getting the connector 101 unplugged and the ground wire bolt out!! pretty tight fit. Good luck
Old 04-06-2005, 05:08 PM
bigdaveangell bigdaveangell is offline
I had the same problem and I had a bulb that needed to be replaced. The bulb looked fine but I replaced it and that was the problem. You should also look for any loose or coroded wires and check the fuses
