Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-14-2005, 07:40 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Bleeding the clutch?
Ok first off the car I am talking about it an 87 jeep wrangler. It has an inline 6 in it. Manual
Hey whats up guys. I have a question..... My father in law has a jeep and he just put a new clutch in. Now theres no pressure in the cltuch pedal and it wont go into gear. We bled the line and it worked for alittle bit but once we let the car sit for about 10 minutes he hopped back to move it and there was no pressure in the clutch pedal and it would work again. We followed the instructions in the chiltons manual on how to bleed the system but we obviously at still doing something wrong.
Any help you guy can give would be greatly appreciated...
1999 Eclipse Spyder GST-Race
-DSM Link,Injen Intake,Spearco FMIC,HKS SSQ B.O.V.,Apex TurboTimer,Greddy Evo Exh 3",660 injectors,Walbro 255 fuel pump,B&M Fuel Pressure Reg,Heads Ported & Polished,Momo Short Shifter Clutch Masters lightened Flywheel,C.M.Kevlar Clutch,Quaife LSD,Autometer Boost & A/F Gauge, EvoIII B16g Turbo,HKS 272/272 cams & HKS Cam Gears,Crower Valve Springs & Rods,Power Pulley Kit,100 shot Zex Nitrous
Old 02-14-2005, 11:34 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Bleeding the clutch?
I'm not familiar with that year's clutch, but it sounds like there may be a leak that's allowing air into the system. check to see that everything you removed/changed is tightened to specs.
-edit- is there anything leaking under the vehicle?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-15-2005, 07:51 AM
I just wanted to add that when he changed the clutch the throw out bearing and also the master cylinder.
Old 02-15-2005, 08:21 AM
I'd check to insure the connections are correct and tight.
Are there any leaks under the vehicle?
Old 02-15-2005, 02:39 PM
I asked him if there was anything leaking under the vehicle and he said no.
Can someone tell me step by step the proper procedure on how to bleed the clutch?
Old 02-15-2005, 11:45 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
bleeding the clutch is like bleeding the brakes; you might have a slave cylinder that's leaking; that's what happened on my dad's '88 Commanche
Old 03-01-2005, 11:11 PM
gettoraiver gettoraiver is offline
Send a message via AIM to gettoraiver
hmmm
i am having the same exact problem with my 88 inline 6 clutch.
I have bled a hundred clutches and i cant get is to bleed
i have replaced the master and slave clutch, throw out, and pressure plate. if you figure it out post a reply.
Old 12-09-2006, 06:13 AM
Guahan Guahan is offline
94 jeep wrangler 2.5 liter 5 speed manual: Need info on where to bleed clutch. Clutch line is right under drivers side. However, I do not see a bleeder valve. Need Help!
Old 12-09-2006, 01:10 PM
dusty341 dusty341 is offline
I have a 87 Wrangle w/ inline 6. We had the same problem......we determind the the cap where you fill your fluid was not sealed. We bought a new cap and our problem went away. Good luck!
Old 12-10-2006, 03:05 AM
Thank you dusty341. The cap I'll look into. Need info on where to bleed the clutch. I am assuming that it is on the slave master. Hopefully will replace allen screw with bleeder valve.
