| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
what can a gsr motor take
can a gsr motor take a supercharger with 8 psi and a 50 shot of nos? well a better question is what is the cheapest most reliable way to make a 95 civic with a gsr motor run 12's
It would handle it fine if you set it up right but building up the motor would be a better choice to handle the boost if you want to boost higher.
~**RRREEEOOORRR!!! I smell....sniff....sniff....SKANKS...why don't you girls just pack it up before I leave TREADMARKS on your faces**~ ![]() ![]() -1994 Acura Integra LS- *AEM CAI* *DC Sport Short Shifter* *Clear Bumper Lenses* * Hyper White Lights* *ITR Shift knob* |
could run 12's, my friend has a 100 shot on his 92civic si and he has a b18c swap and ran 13.3's with full interior on slicks
My car is like my own personal universe, shes my drug and it only takes twelve bucks to fill her up, but in my galaxy there aint no room for earth, so im leaving it cause i can feel the oil pressure building up, turning over thee ignition of my solar system, check the gauges, push in the tape, put my foot on the brake, shift exsistance, light my ciggarette and take it state to state until i crash into my fate |
the b18s could handle 7-9psi for about 30,000 miles then they starts to give you problems. I wouldnt recommend anything higher than 9 psi. Talking about NOS, if you run it enought times your valves, valve springs and cylinders will become one nasty looking piece of metal. Aluminum engine + NOS = bad idea. i got pics. i'll post them if i can find them.
Powered by Honda. NA tuned at 11.8:1 |
CAREFUL tuning and you'll be good with 8 lbs and a 50-shot. Just tune carefully before you use the N2O, and don't squeeze it too much. I agree that valve springs and retainers are a good idea to change out before trying to run the set up, and if you can afford to rebuild the bottom end, it's definitely not a bad idea, though I wouldn't call it a necessity. And I'm pretty sure that if your hatch is.. say about 2,300 lbs or less, you tune the motor right, and you can race well, you should be in the 12's.
![]() » Supercharged 2006 Honda Civic Si Coupe » Info | Teaser Video | Dyno Video | Dyno Graph |
so what all would need to be done to make it more long term?
