Old 02-14-2005, 12:59 AM
nikboca nikboca is offline
Door Locks
I have a 1995 honda accord 4dr lx. and the power locks only work on the drivers side rear door. They make noise for the passenger side but don't work. How can I fix this?
Old 02-14-2005, 07:53 PM
Igovert500's Avatar
blue + red light magnet
Re: Door Locks
Hey, welcome to AF. Power locks and windows tend to be a problem with our cars, but they are usually pretty simple to replace.
It could be a few things, your power window motor, the regulator, actuator, a little piece of plastic getting caught and jammed.
Your best bet is to take the door panel off and see what is going on inside the door when you press the lock button. Once you find the problem, rather than buying a new motor or something from the dealership, I suggest trying to get a used one from a junkyard or another member selling one on here, as you will find it MUCH MUCH cheaper.
http://www.automotiveforums.com/vbul...ght=power+lock
I did a search and found these two threads that might help you out. You might want to run a search to find more info as well. The search feature is at the top right of the screen, I did a search for "power lock" and found a ton of threads. Hope that helps.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
