Old 02-13-2005, 11:22 PM
Sp3cops70's Avatar
Sp3cops70 Sp3cops70 is offline
Send a message via AIM to Sp3cops70 Send a message via MSN to Sp3cops70 Send a message via Yahoo to Sp3cops70
Need some assisstance???
first off....one of my headlights has some condensation in it....any ideas on how to get rid of that..without having to buy a new headlight???
Second...the front of my fog lights look really ugly...i mean really dirty...but it is not dirt...it is really rough looking and to the touch...anyway to clean that? if not... do you all know of any sites or companies like autozone who carry these stock fog lights besides the dealer??
P.S......Where exactly is the O2 sensor located?? the one that helps with better fuel mileage??
Thanks in advance!!
97 GPGT, 3.8 L
Old 02-14-2005, 10:20 AM
stlwagon stlwagon is offline
Re: Need some assisstance???
We all suffer from headlight condensation. Some have removed and coated joints with silicon but don't know how well that works.
Big-L can provide details on aftermarket foglights. You can try cleaning the existing light with toothpaste (not get, regular colgate). The light silica grit will sometimes polish out small pits or scratches.
We have 2 O2 sensors. First is in the rear exhaust manifold near the #6 plug. Second is in the exhaust, just aft of the CAT in the u-bend. The first one is going to cause your gas mileage problems.
Old 02-14-2005, 01:15 PM
Sp3cops70's Avatar
Thanks.....BigL u know where to get the stock fog lights without having to go through the dealer???
Old 02-14-2005, 01:59 PM
BIG-L's Avatar
BIG-L BIG-L is offline
You can buy some Cyber Whites Part # NV-602W from Walmart for about 40 bucks for a pair.With little modifying they fit.They are the same size as stock (4in) just have to modify the bracket.They are much brigther then stock since they use an H-4 55W Halogen Bulb VS the stock 880 bulb at 28 watts.
~Larry~
ClubGP Member 6530
Since 2001
Old 02-14-2005, 03:38 PM
jon95se jon95se is offline
is it just me, of if either o2 sensor is bad, it can cause bad gas mileage?
Old 02-14-2005, 04:23 PM
BIG-L's Avatar
The upstream O2 monitors Fuel and air.It is the primary measurement device for the fuel control computer in your car to know if the engine is too rich or too lean. The O2 sensor is active anytime it is hot enough, but the computer only uses this information in the closed loop mode. Closed loop is the operating mode where all engine control sensors including the Oxygen sensor are used to get best fuel economy, lowest emissions, and good power.
The Down stream O2 monitors the effectiveness of the catalytic converter.
ClubGP Member 6530
Since 2001
