Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 02-13-2005, 10:14 PM
jnp59 jnp59 is offline
Will just quit running
My 1985 Olds 98 will just stop running when driving or idling and when I try to restart it, it will start right back up or I will have to let it sit a bit before it will start. Can anyone help thanks.
Old 02-16-2005, 08:38 PM
Hansnet's Avatar
Hansnet Hansnet is offline
Re: Will just quit running
is it the V8 or a VERY rare 3.8 v6??
Old 02-16-2005, 10:54 PM
A re-manufactured 3.8 v6 replaced in 1997 and has 20,000 on it and also has the round type distributor.
Old 02-16-2005, 11:17 PM
Hansnet's Avatar
oh I was thinking it was an 88 for some reason.
Was the engine from GM directly or did someone rebuild another engine from another car???
The reason I ask is the Engine from 85/86 was different from 87 and 88 was different from 87. If it was not the EXACT same revision of that motor you might have some issues with the pcm but assuming it is....
It could be a variety of issues, so I will start out with the easiest to fix:
FPR (fuel pressure regulator)
IAC Valve
TPS is bad
MAF is bad
Clogged Fuel filter
Intermitent (dying) fuel pump
Bad coils.
What do you mean it has the "round type distributor" If you are saying it has delco instead of the magnavox this was not even offered until late 1987....
Old 02-16-2005, 11:49 PM
It's from a company call Engine & Transmission Exchange, INC. I thing when they replace a bad engine with one of there re-manufactured ones they rebuild the bad one and put it on the shelf for the next customer. What I mean about the round type distributor is the type thats in the older cars like from the 50's 60's and 70's were the cap itself is round.
Old 02-17-2005, 01:15 PM
Hansnet's Avatar
do you have any photos of the engine bay???
does it look like this:
That motor has to be quite rare, 86 was much different from what I can tell.
Refer to my previous post on what to check.
Old 02-17-2005, 01:45 PM
Yes that is what it looks like.
Old 02-17-2005, 07:04 PM
auto trainy auto trainy is offline
It sounds like a v8 with a carburator,right?
Old 02-18-2005, 07:43 PM
1990TS 1990TS is offline
1985 3.8's used in FWD C-body applications still used an HEI distributor. The D.I.S (distributorless ignition system) was not used on these cars until 1986. Most likely needs a MAF (mass air flow senser.) Do a Tap test on it when the engine is running and see if engine stalls. It's located between air cleaner box and throttle body in the convaluted air tube. (tap on it lightly with a screwdriver) These were a problem on the 1985's but then again it could be a lot of stuff after 20 years of use. But start there and repost if you need more help.
Old 02-19-2005, 06:13 PM
Thank's Hasnet and 1990ts I now have some new knowlege,then again I haven't followed every single model.
Old 02-27-2005, 09:54 AM
Re: Re: Will just quit running
Thanks for your help it ended up being the control module.
Jeff
Old 02-27-2005, 09:55 AM
IAC Valve
TPS is bad
MAF is bad
Clogged Fuel filter
Bad coils.
Thanks for the help it ended up being the control module.
