ZX2 no start condition after CEL
I was driving my girlfriend's 00' ATX, when the engine started to "chug" when the car slowed. At the stop sign the car died, but started back up. The CEL came on following startup and the transmission was very unresponsive and had trouble getting into 4th gear. When I got back home I shut off the car and went to bed. The next day I went out to start it and the engine wouldn't turn over.
THIS IS IMPORTANT: The starter spins BUT the motor does not. (I've posted this in other forums and people just didn't get it!) I tried to get an OBD-II scan tool, but it is presently being serviced. My next step was to remove the starter and "hot wire" it to see if the armature inside was working and the starter gear would extend into the flexplate. I'm also going to take a look and see what the flexplate looks like. If you have any ideas that may help don't hesitate to post them! Thanks, Aaron |
Re: ZX2 no start condition after CEL
Look down inside the valve cover through the oil fill while someone cranks it over. If the valvetrain ain't movin', that's what happened.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
I don't think so, but I will look.
I know what a snapped or off timing belt sounds like (unfortunatly). |
Re: Re: ZX2 no start condition after CEL
Re: Re: Re: ZX2 no start condition after CEL
I had an old chevy in the shop once, sounded like the timing chain broke. EXACTLY like it. Luckily, I had someone crank it for me while I checked to see if the distributor was turning. It was then that I noticed that the crank wasn't turning either. The ring gear came off the flexplate, and was just spinning around the outside of it when you cranked the starter. Never seen that before. Never know with cars what they'll think of.
Cams move! Still no start!
'93 PGT: KL-ZE '92 FEL: B6T-DE '89 PGT: F2T-DE |
If teh car was chugging while it did run, teh transmissions isnt acting right and you cant get it to restart i'd think maybe the PCM went, i cant think of anything else that would effect the motor AND tranny
Hmmm. Still might have jumped time. Or not.
Are you able to pull the code?
You said the starter wasn't engaging, what became of that? (wondering how you verified cam movement without starter) Confused.
I also used a Genisys scan tool to check the codes. The only one available was P1000: (something like) "Drivablity Tests Unfinished" Why would the ECU just up and die... sounds weird. The car is a 00 this stuff shouldn't happen to cars that are this new. Is it posible that the fuel pressure regulator went bad and when the injectors fire they supply full fuel pressure? I don't know I'm running out of ideas... I'm going to go and look up P1000.
'93 PGT: KL-ZE '92 FEL: B6T-DE '89 PGT: F2T-DE Last edited by Mazda_Power; 02-23-2005 at 01:58 AM. |
Im on my 4th PCM in under 3 months
The only other time I remember running across a full rich fault like this where it would drench the plugs with fuel instantly, the coolant temp sensor had been damaged and was telling the ECM something really wrong about engine temp, but this was shown by a code that the reading was out of range. Your code (granted, I'm not familiar with recent Ford codes) sounds like what might happen if a self-test was not going correctly. Make sure any grounds associated with sensors or the ECM are intact before you replace it.
Yours isn't that bad, but along the same lines. I doubt you're spraying with the ignition off. I don't think that's really possible, the way they are set up now. Have to have a dwell signal from the ECM to spray.
