Old 02-13-2005, 09:52 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
1 SE 12" or 2, maybe 3 RE 12"
Ok, I have my heart set on a single SE 12" in a ported box, 2.5cuft, 32hz, and Now that I see the wonderful group buy price on soundillusions.com, Im wondering If i should just get 2 or 3 12" RE subs, in a sealed box?....Ok...I want some help here, they are just so damn cheap, and I read they are comparable to JL w3's, and I like the way those sound. Sooo.....I want some help deciding on this one. I want quality bass over quanity here....
Thanks
Old 02-14-2005, 11:43 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: 1 SE 12" or 2, maybe 3 RE 12"
3 12's would be pieeemp..... port it.....because when you port it the bass will come!!
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 02-14-2005, 12:54 PM
How big would a box for 3 RE 12" ported be?.....I can ony go about 13.5" deep, but i can go as wide as I want (say aobut 40-45" or so, have to pull ou the ole tape measure again) or basically as wide as the truck is...?
Old 02-14-2005, 01:13 PM
Ok, now I got another question, what kind of amp should I run if I get the 3 12"...It says 175RMS, 250Max, and I have my pos Xplod 4ch amp. I assume I need to get a new amp. I can wire those 3 subs to run at 2.67ohms, will it hurt an amp to run at 2.67ohms, I wouldn't think so, but I figured I should ask. I am looking for something cheap (amp wise) here....
Old 02-14-2005, 06:18 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
No, 2.67 ohms is pretty easy on most amps, unless its like a 2ch thats only stable to 4ohms bridged.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 02-14-2005, 08:07 PM
I'd get a mono amp from profle to power them..... something that gets 450-800 watts at 2 ohms.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
