Old 02-13-2005, 10:07 PM
92FRESHEE 92FRESHEE is offline
Transmission Problems
I pulled out of the gas station the other day and my car felt a little sluggish. I was hitting the gas but the rpms weren't going above 2500. A little puff of smoke came from inside on the passengers side. Also, on the dash when I put the car in drive the park light also illuminates. I want to try and find out some info. before bringing it to someone. Please help!!!!!
Old 02-14-2005, 12:05 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Transmission Problems
Yikes. That doesn't sound too good. Sounds to me like some wiring got crossed up in the dash. You install anything lately?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-14-2005, 12:11 AM
Igovert500's Avatar
blue + red light magnet
Do you have any Check engine lights or any flashing lights indicating a problem?
Also, what year is your car, what's the mileage, and is it stick or auto?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-14-2005, 01:16 AM
Re: Re: Transmission Problems
The only light that has been coming on is the break lamp light. My car is a 92 accord ex and it has about 156,000 miles. It's an automatic.
Old 02-14-2005, 07:20 AM
AccordCodger AccordCodger is offline
From where? If it was the A/C vents, and the ambient conditions were just right AND you had the a/c on, and ... and ... etc ---- it might just have been condensation and unrelated to your problem.
If it was from any place else, as the man says -- yikes!
Old 02-14-2005, 07:22 AM
I should add the the "yikes" (in my case) was because I've had a car catch fire while I was driving it (a VW bug) and I only detected trouble when it started to misfire. The I looked in the rear view mirror and .... !
Old 02-14-2005, 09:19 AM
The puff of smoke came from near my fiance's feet. Whatever that means.
Old 02-14-2005, 12:17 PM
Was anything going on at that time that could have been a factor(using the lighter, hit a bump, closed the glovebox, anything?)
...empty gun rack.
Old 02-14-2005, 12:19 PM
Did the smoke have a smell, electrical, fluid, etc?
...empty gun rack.
Old 02-14-2005, 12:20 PM
Where is the ECM, PCM, ECU, whatever you Honda folks call it on his car? (sounds suspect if it's over there on the pass kick panel or is it underhood?)
...empty gun rack.
Old 02-14-2005, 12:21 PM
Is your fiance prepared to ride in your car - ever - again?
Someone help me out here - where is the TCM? Is it under the passenger seat?
Old 02-15-2005, 06:40 AM
BIAR BIAR is offline
The tcm and pcm are under the pass floor board,where her feet would be.I have never heard of one smoking before,but that is where it is at.If you lift the pass side carpet up you will see a metal panel,the tcm is on one side and the pcm on the other.Carl
Old 02-15-2005, 07:56 AM
After thinking about it I have heard of customers complain about puff of smoke before.You might try a junk yard if they will warranty it for you.If you buy a new one I would let the dealership put it in.Because the ab shift solenoids sometimes short and will refrie the new tcm.If they fry it,you are covered.Carl
