Old 02-13-2005, 08:36 PM
JoshBarber JoshBarber is offline
Question Heated Seat not working
My passenger side seat doesnt heat up. When the switch is on, you can feel warmth slightly around the switch area itself, but it never heats up like the drivers side does.
anyone know what to do?
Old 02-13-2005, 09:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Heated Seat not working
How about taking a look at the switch connection.
This is some obvious stuff bro, no offense, but you pointed out to yourself what you should look at.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-13-2005, 09:30 PM
Re: Re: Heated Seat not working
just wanted to see if there was a common cause. I learned from asking about the possible front end noise (which was really vague) ended up having a simple cheap cause with the hood noise....which ended up saving me a boatload of cash. Had I not asked, I may have started replacing ball joints and everything else.
I will take out the switch and look at it. Anything obvious that I should be looking for? Broken wires?
Is there a seperate fuse for each seat? Drivers side heats up quick and hot. Passenger side remains cold.
Old 02-13-2005, 09:48 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Heated Seat not working
You seem to be on the right path.
Old 02-17-2005, 07:27 AM
Re: Re: Re: Re: Heated Seat not working
pulled the switch for the heated seats/Lumbar on the passenger side. The lumbar switch works fine, but the heated seat does not come on. Unfortunatley the wires are soldered right to the switch...no connector so remove the switch and work on it inside. I don't see any obvious problems with it.
Anyone else have a problem with your heated seat not coming on? Did you fix it?
Old 02-17-2005, 11:00 AM
switch is fine. gotta be the heater coil in the seat. Not even gonna attempt that one.
Old 02-17-2005, 02:58 PM
BlazerLT's Avatar
AF -Advisor
There was a heated seat how to just posted recently, I suggest you read it and learn how to take your seat apart and check it.
You sure the switch is fine?
Old 02-17-2005, 04:03 PM
sure the switch is fine.
Old 02-17-2005, 04:08 PM
BlazerLT's Avatar
AF -Advisor
Check out the heated seat thread rlith just created recently.
Old 02-22-2005, 02:54 PM
Question two connectors?
two connectors underneath the rear or the front passenger seat. one big, one small. Can someone tell me what each is for? I only have lumbar control and heat. Not power movement.
Old 02-22-2005, 03:49 PM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
I will tell you what to do Josh....
Go to AllDataDIY.com and subscribe one year for vehicle. It will give you every diagram, procedure, drawing, TSB, recall, diagnostics for your year vehicle. It cost's $24.95 for one year...the best money you could spend. It also tells you part numbers, labor time so you can get an idea what a dealer would charge prior to your own DIY efforts.
Go there and check it out..you can save alot time waiting for someone to post, versus you learning, and self diagnostics....check it out it's a cool site.
Old 02-22-2005, 04:08 PM
blazee's Avatar
blazee blazee is offline
Problem?
I just want to congradulate you Josh you have broke the record and have started more threads in your first month than anyone in the history of this forum.
Old 02-22-2005, 04:21 PM
Unhappy Re: Re: Heated Seat not working
sorry.
Old 02-22-2005, 04:27 PM
blazee's Avatar
Problem?
Don't be sorry, this forum is here to help people. If someone doesn't like your thread they don't have to read it.
Old 02-22-2005, 09:44 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
I think he has also set the record for the fastest to make it from Newbie to enthusiast.
At this rate Josh, You'll be a Moderator by 2006! Keep up the good work Josh, at least you've got the guts to try!
