| Off-Topic Talk about anything other than cars. |
2nd o2 sensor
I have a 97 tsi awd and i just ordered the rre downpipe with the test pipe. My question is, that i saw some people talking about wrapping the 2nd o2 sensor in foil to keep the cel from coming on. So i was wondering if i am supposed to put it back into the hole or keep it outside and tie it up somewhere. Thanks for the help.
Tie it off somewhere. Also it would be a good idea to cover it with something like a plastic bag so water dosent get in and stuff.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it") 98 GSX 5 spd. (Currently stock, spending all my mod money on body work.) |
Re: 2nd o2 sensor
If there is a hole in the test pipe, put it in. If there is no hole, use the tin foil and make sure it doesn't break.
thanks alot
well, i have a hole for it, so should i just not bother with the foil?
Re: 2nd o2 sensor
why wouldnt you use it? you'll have to plug the hole anyway.
Re: 2nd o2 sensor
if he puts it in with a test pipe then he will get a CEL. wrap it in foil or pack it with jbweld(havent tried this one but it should work) then put it back in the hole
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
ya, thats what i was thinking, but i had just heard of people talking about tucking it up under the car. So i guess im just gonna wrap it and put it back in. Its worth a shot.
Re: 2nd o2 sensor
you can just stick it out of the way but then you need to plug the hole in the test pipe. btw a spark plug is the same threads and size as the o2 sensor so you can plug the hole with a old spark plug.
ok sounds cool, btw how does covering uo the sensor in foil help anyways?
Re: 2nd o2 sensor
I have a 3'' apexi downpipe and an o2 sensor in it which throws no CEL.
ok sounds good, im just gonna see if it comes on first, and i f it does then ill wrap it
