finaly some pics of my poblems
i posted a few weeks ago a problem with my ignision and i have finaly some pics to show you guys what i mean
this is the car with the key in the ignision this is the car with the key set to A/C this is the car with the engine turned on and the engine temp at normal decided to throw a pic of the car from a few days ago as well and yes thus is iceland and we dont have snow even in late january when this pic was taken
Re: finaly some pics of my poblems
check your throttle cable it may be to tight there is a sliding bracket that you can adjust right above the throttle body, thats a crazy high idle.
1995 3000GT SL (RED) My mods: Custom true dual exhaust with x pipe K&N FIPK 17 inch forged aluminum billet rims from WELD EVO
ohh yea i forgot. on the 2. picture the car is not running and as you can see it's 500rpm's all the same! the meter shows that the engine is running 1400rpm's but in fact its just 900rpm this is some kind of a electrical glitch
oh..... ok wow thats really weird bet that throws off your shifts.
so wahts your problem?
Lol whats the problem? The gauge is saying he has 500 RPM going when the engine is off! Dunno what would cause that, its a very strange problem.
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
yea it bugs the hell outa me!!! i dont think it affects the shifting thoug in normal driving it shifts gears when the meter shows 2500-3500 rpms 2000-3000 real time rpms
probly ECU problem...not worth buying a whole ECU to see if it is...or the $60 to have a Diag. done on it...i'd say u should just deal with it...think of your car as special b/c it can be at 500 RPM's when it's not even on
it was born ready.
Its strange, I say ask over at 3SI because there are lots more people there who might have seen this before.
I havn't given up yet, I'm still searching a few places, 3si being one of them. Quick question, you mentioned something about installing an MSD right...when did this start occuring in relation to when the MSD was installed?
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
"Also under the coil packs is a small flat black box.It is the ignition control module.There is a pin labled tach.Make sure you have a good connection and maybe check to see if you are getting a signal at that pin but a little bit back down the wire."
Something I found, not sure if it will help though.
thanks allot igovert500 you have been a realy great help for me the past few days
i have not put in a msd (and will probably not on this crapy sohc motor) put i will definately try the coil pack thing
