Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 02-13-2005, 06:06 PM
96CivicEX06's Avatar
96CivicEX06 96CivicEX06 is offline
Send a message via MSN to 96CivicEX06
After gauge install...
I just recently installed my Indiglo gauges and they work absolutely fine. None of the needles are broken, and the mileage counter and the trip worked as they should until my car went 79,000 miles and the trip and mileage counter completely stopped. You can see where the 78,999 is starting ot turn to the 79,000 mile point and it just sits there, just as the trip does. I'm wondering what could be the problem here. Any ideas?
Silly ricer, wings are for planes
Old 02-15-2005, 07:48 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: After gauge install...
happened in my talon. in my case i just pushed the trip-o-meter reset a few times, and it took care of the problem. dunno y it happened, but wutever it was, fixed itself by getting reset.
Old 02-15-2005, 07:58 PM
Ok thanks, I'll have to try it. It might just be a coincidence, because I didn't touch the odometer or trip-meter while installing the indiglo's, so we'll see.
Old 02-16-2005, 03:56 PM
fakehatch fakehatch is offline
I'm also having a problem w/ my cluster. My MPH dial won't work and won't count miles, trip also doesn't work. But, my gas and temp gauges work fine. Then it'll just jump up and start working for awhile, then die. Sucks to not now how fast your going or when to change your oil. Does anyone else have this problem>??
Old 02-16-2005, 04:14 PM
What you could do is see if the plugs that connect to your cluster are plugged in all the way, if they are... then you have broken needles.
Old 02-18-2005, 11:40 AM
could be a bad ground, bad speeds sensor, bad connection or wire from the sensor to the gauge, or like 96Civic said, a loose connector behind the cluster.
