Old 02-13-2005, 06:42 PM
90sabre 90sabre is offline
Question reverse lights
I have a 90 LeSabre Limited and my reverse lights are not working. I replaced the bulbs and nothing. The turn signals work fine. I noticed tonight that the reverse lights appear to flash briefly when shifting between park and drive. I am thinking this may be related to my gear "shift indicator" not showing what gear I am in. For example when it shows reverse, I am actually in drive. Any suggestions on how to fix these problems or if they are even related? Thanks!
Leo
1990 LeSabre Limited
Old 02-13-2005, 11:20 PM
yogi_123rd yogi_123rd is offline
Re: reverse lights
Look on the transmission where the neutral safety switch is (on the transmission where the gearshift cable connects to). The neutral safety switch detects when the car is in park or neutral. You will find a second switch for when you are in reverse gear. This second switch lights up your backup lights. Since it sometimes works, it may just need an adjustment of some kind.
Old 02-14-2005, 06:40 PM
Smile
Thanks for the info, I'll check that out. Will it be obvious which switch is which?
Thanks again,
Leo
Old 02-14-2005, 08:22 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: reverse lights
You only have one switch on the trans. You have 2 bolts that hold downthe safety switch, loosen the 2 bolts and move the switch till the lights work while in reverse. Your indicator is attached to your shift bowl by a cable. You will need to get to the cable and unclip it move to adjust your indicator.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 02-15-2005, 12:05 AM
Thanks, I'll try to get under there in the next couple days and take a look. Hopefully, it's something that simple.
Thanks again to all who posted!
Leo
90 LeSabre Limited
