Old 02-13-2005, 03:51 PM
YoBoyThacker YoBoyThacker is offline
Send a message via AIM to YoBoyThacker
Angry Problems with surging on my 89 civic
I have a 89 civic HB (1.6L), i am getting a surge when idling and when i acelerate i get a delayed response, like if I floor the gas and it'll like studder like the fuel's not reaching the engine??? I have a feeling that i am not getting enough fuel but not sure where to turn, any help will be appreciated, I've heard An 02 sensor might be the problem, or i've been told that a new fuel filter might help me out. Does anyone know how to change one or where it's located??? i'm pretty much in the dark right now so thanks for any help........
Http://www.cardomain.com/id/89whitesi
Originally Posted by sivic02
I have decided I am taking over the world and I have simple solutions to world problems.
The world is becoming crowded and people are stressed out. Here I can kill two birds with one stone. Every person is allowed to kill one person. You get a get out of jail free card.
Old 02-13-2005, 08:35 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
it could be the TPS...and some vac. lines the vac lines will cause the idle problem...and the tps will cause the response to be like a half sec or so and could make the car stall out sometimes. check your ecu for codes. do you have a check engine lite on? to check your ecu for codes, pull back the passengers side carpet. you will see a bronze looking metal cover with a little sight in it, there is an led in there. start the car and count how many times it blinks. different codes will be separated by a slightly longer pause. do that and tell us what you got.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 02-13-2005, 09:18 PM
Re: Problems with surging on my 89 civic
alright i checked it and i couldnt really tell but i think it was 17 then paused for like a half second longer than kept going and didnt get much, let me know anymore pointers you got, thanks again
Old 02-27-2005, 07:17 PM
anyone??
Old 02-27-2005, 07:52 PM
4true's Avatar
4true 4true is offline
Registered User
Send a message via Yahoo to 4true
fuel filter maybe?
Old 02-27-2005, 08:35 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
throw in a new fuel filter and a injector cleaner and see if it helps at all
for the surging, check for any vacuum leaks, if nothing then unplug your iacv, does it stablize yoru idle ?
Team Lonely Drivers
Old 02-27-2005, 09:05 PM
Scott82 Scott82 is offline
Code 17 is vehicle speed sensor in the chart i am looking at?? but i am pretty sure you have a spedo cable and not a sensor so i don't think this could be the case. Count your flashes on the ecu again
Old 02-27-2005, 09:06 PM
also code 16 is a fuel injector and there is no code 18
Old 02-27-2005, 09:08 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
could be your MAP sensor on the fire wall check connections.
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
