Old 02-13-2005, 03:13 PM
Str8in Str8in is offline
Banned
Send a message via AIM to Str8in
6/7bolt
Is there any difference between a head that came off a 6 bolt motor then a 7bolt motor? i.e can a head that came off a 6bolt motor fit on a 7 bolt block?
Old 02-13-2005, 10:41 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: 6/7bolt
it is the same motor yes you can use the head off of a 6-bolt on a 7-bolt you should search first
Old 02-13-2005, 11:03 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Re: Re: 6/7bolt
It may be a good idea for you to also do some searching.
You are correct that a head from a 6 bolt motor will fit onto a 7 bolt head, however the stud holes will be larger then need be in accepting the bolt size which creates room for moving. This is never an issue when you have the guides installed anyway. As stated, the differences include the size of the head bolt holes, (which are 11mm for 7 bolts, and 12mm for 6 bolts respectively), and their flow characteristics, which is a different story. Thus, you won't be able to put a 2g head onto a 1g motor, at least without modification. I have successfully installed a 2g(7bolt) head onto a 1g(6bolt) block. What has to be done to do this is the stud/bolt holes in the head will need to be drilled out 1mm more to accept the 6 bolt(12mm) studs/bolts.
Therefore, the swap only goes one way, unless you put some work into it.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 02-14-2005, 10:47 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: 6/7bolt
It may be important to note that not all 1G's are 6 bolt. I believe that only the 1990-1992 were. 93-94 are 7 bolt.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-14-2005, 01:15 PM
Re: Re: 6/7bolt
This is absolutely true. I was assuming that this was known, but I guess it was worth throwing out there.
Aaron B.
52.7 1/4 second try
6.6 55 meters
Old 02-14-2005, 02:02 PM
Banned
Re: 6/7bolt
thing is im looking to put a head off a 90 (of course its a 6bolt) on my 7 bolt block cuz i kno someone that had the valves bent on it so i could get it for cheap, plus i only want the shell of the head to fully rebuild it so i dont wannt pay $150 + for a head that im going to tear apart and put bak together with all different parts. Thanks for the help
Old 02-14-2005, 09:25 PM
Re: 6/7bolt
Taking a 6 bolt head and installing it onto a 7 bolt block is a commom upgrade. Therefore yes you will perfectly fine doing this. If he is looking to make any good power, investing in a good set of ARP's would be wise as well. Good luck!
Aaron B.
52.7 1/4 second try
6.6 55 meters
Old 02-15-2005, 11:08 AM
Re: 6/7bolt
About how much do the apr head studs run i will be needing some of those
Old 02-15-2005, 01:21 PM
Re: 6/7bolt
They usually cost ~100 bucks. Worth every penny.
Aaron B.
52.7 1/4 second try
6.6 55 meters
Old 02-15-2005, 02:46 PM
i1nk83 i1nk83 is offline
Send a message via AIM to i1nk83
you could also look into getting a 1g head from a 92.5-94. it will still have all the items you are looking for but will have the smaller diameter bolt holes etc. it still has the larger ports etc with none of the downsides.
1990 mitsu eclipse gsx
16g
550's
burned eprom chip
2g mas
3" turbo back custom exhaust
port&polished head, turbo, exhaust mani
mml headgasket
b.s. elimination
centerforce df2
unorthodox crank pulley
autometer boost , a/f
hallman es mbc
homemade fmic and piping
relocated battery lower in engine compartment
purty candy red valve cover
stripped interior
couple of random guages
man this is a big list of nothing special......gotta work on that
50trim in the works
