Old 02-13-2005, 03:08 PM
vica vica is offline
keyless entry programming
I want to program a factory keyless entry transmitter. I have 1995 Chevy Silverado with the 454 engine and power door locks. I have read information that speaks to shorting pin 4 to 8 on the OBD connector under the dash. I believe that pertains to the OBD II and I assume my pickup is OBD I because the connector has 12 pins and not 16. I have also read information that speaks to shorting pin "A" to pin "G". Again my connector appears to be different in that there are no connector pins in places "A" and/or "G".
Am I missing something or is there a third type of connector configuration? Any help would be appreciated.
Old 09-29-2009, 11:03 PM
Jason55 Jason55 is offline
Re: keyless entry programming
I have the same problem... just wondering if you were able to program your remote?
Old 09-30-2009, 07:32 PM
wafrederick wafrederick is offline
Banned
Or you have the wrong key fob,numbers on the back of the key fob have to match the vehicle and there is a tester made by Kent Moore to test this.I know what the tester looks like and most dealers have it.
Old 10-01-2009, 08:43 PM
I have the correct remote, but I can not get the truck to go into the programing mode.
Old 10-04-2009, 09:54 PM
dougger dougger is offline
Hope this helps. Here is the links I found that tell how to do this, not sure what years this works for, good luck!
http://www.ehow.com/how_2258489_prog...silverado.html
http://www.wikihow.com/Program-a-Key...hevy-Silverado
Old 10-12-2009, 12:06 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Make sure you are reading the pin layout correctly. The wider row is considered the top, many DLC connectors are mounted upside down.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
