Old 02-13-2005, 02:55 PM
user123456 user123456 is offline
Question Tachometer reving while in gear
Lately, I noticed that while I am driving, if I pump the accerelator, the tachometer will go up and down in a wide range. The truck will jerk as I step on the gas to accerelate but the tachometer reading is now moving like I am in neutral. My transmission fluid level is good but I have not change the fluid filter for the last 80,000 miles. Should I worry?
Old 02-13-2005, 03:04 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Tachometer reving while in gear
Sounds like you transmission is slipping.
When you stomp on the gas the truck will not accelerate much by the engine will get faster?
Is that what you are saying?
Have you checked your transmission fluid with the engine running lately?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 02-14-2005, 02:52 PM
Re: Re: Tachometer reving while in gear
Thanks for replying, yup, that's what I meant.
I check my transmission fluid and it looks ok. Should I Change the transmission fluid filter? I am planning to tow a big trailer this summer.
Old 02-14-2005, 09:47 PM
BlazerLT's Avatar
AF -Advisor
You won't be towing anything with the transmission like this.
Sounds like it is slipping badly.
Old 02-15-2005, 02:49 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
What year is this truck? What type of engine/vin number? Are you getting all gears? Is it shifting alright through all the gears and into overdrive? It sounds like your still driving it. Before giving up on the transmission, depending on what year/type, I'd be checking some simple things first.
