Old 02-13-2005, 02:42 PM
adamwood78 adamwood78 is offline
Question radio will not turn on
01 F20 with 6disc cd radio. Will not turn on or do anything, only says phone in the bottom left corner and the time. Need help.
Old 02-14-2005, 03:30 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: radio will not turn on
did you check the fuse?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 02-14-2005, 03:38 PM
Re: Re: radio will not turn on
I checked three fuses that had anything to do with the radio.
Old 02-14-2005, 03:51 PM
J-Ri's Avatar
Try pulling the radio and checking for power at the connector. If there's power, could be the radio has broke.
Old 02-17-2005, 10:38 AM
Rbo Rbo is offline
One more thing to check behind the radio would be if you do indeed have both Constand Pwr (Lt Green/Purple) and Acc power (Black/Pink) behind the radio would be, to check and make sure that the mute wire isn't shorting to ground somewhere. There is a wire back there that is a mute for your cell phone. When it sees ground it will override the stereo. I'm not sure of the color but go and buy an aftermarket deck harness and match the pin placement to find the mute (Brown) wire in the aftermarket harness and see if that is it.
