| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
99 I30 oil burner
any ideas why what seems like all of a sudden my i0 started burning alot of oil. also what does the odb II CODE P0422 EGR flow malfunction mean?
Re: 99 I30 oil burner
What is "a lot"? Error could be just that, compression bypass into engine crank chamber. Do compression test to check for possible piston ring problem.
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
nearly a qt per week. is it possible that the o2 sensor and egr could cause that to happen, burn oil that is. i changed the o2 sensor tonight.so one problem down. the scan i took prior said bad sensor and egr malfunction, i figure one went with the other. wil check compression as soon as i can .. thanks
Re: Re: 99 I30 oil burner
If u say one qt per week, I read its leaking...? One qt per 1000miles is not bad [but maxima it should be none] Oil burn has two causes [burn, not leak]: 1. Piston rings do not wipe oil down as they travel, get combusted. Major overhaul. Check by compression tst. 2. Valve seals. Can be changed while engine on using compressed air into cylinder under operation [keeps valves from falling]. 2hours? plus parts 50$?
thanks, i'll check it out.
i'm told my problem could be a clogged pcv valve causing the oil burning. worth a try to change it , but i can't seem to find it. can anyone tell me were it is located. the thing is small i'm sure i looked right at it already.
try www.autozone.com ,chiltons goodmorning manuellos, free login
i'll have a look. thanks
OOPS. Corrction: Btw u have to take cams off and that means belt off (+4hours) Ref: 2. Valve seals. Can be changed while engine on using compressed air into cylinder under operation [keeps valves from falling]. 2hours? plus parts 50$?
well that's what it was a clogged pcv valve. cya
"nearly a qt per week" ...onlY PCV???
so far everything is fine i'll let you know after a couple of weeks.
well it's ben a couple of weeks and the oil burning has stopped. so check that pcv valve or just replace it. it cost less than 2 qts of oil.
Good to know, thanks. Chances are, lifetime goes without any pcv problem.
