Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-13-2005, 12:53 PM
unreal5 unreal5 is offline
96 Laredo, transmission, acceleration, or sensor problem
Hey guys,
Had great success on this board. I have a 1996 Jeep Gr. Cher. Laredo, 4.0L 6cylinder with just 88k. The problem is that the vehicle does not accelerate well at all. The vehicle shifts fine at 3rd and 4th, but takes a bit longer to get into 2nd gear. When you 'floor it' and give it a lot of gas, it really doesn't start the acceleration until 2000 rpms, then everything is fine. Shifting is fine, I have been driving at 75 no problem. Reverses fine, just very poor acceleration. I have heard that may have something to do with a sensor, no check engine lights though. Any ideas? Thanks.
-Anthony
Old 02-13-2005, 05:18 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 96 Laredo, transmission, acceleration, or sensor problem
hCheck the transmission fluid and level. if smells burnt or is brown or low fill or replace.
Old 02-13-2005, 10:02 PM
jeepdwg jeepdwg is offline
Pull the codes on it. The check engine light may not be on but codes may be present.
Have the Throttle Position sensor checked, it may be bad. I had a 92 Cherokee that had similar problems, I replaced that and the coolant sensor as the diagnostic said those were suspected bad.
