Old 02-13-2005, 12:25 PM
ChevyCav ChevyCav is offline
2000 Cavalier Brake light Probs
I have a 2000 chevy Cavalier. Recently the 2 of the 3 brakelights stopped working. The 2 near the trunk won't light but the one in the back windshield works fine.
Fuses and bulbs are all good. I even replaced them just in case.
The hazzard lights also work fine it's just those 2 brake lights.
Any ideas???
Thanks,
Billy
Old 02-13-2005, 04:58 PM
cousincletus cousincletus is offline
Re: 2000 Cavalier Brake light Probs
GM had a problem with the bulb sockets. Try new bulbs first but keep in mind the sockets may be bad.
Old 02-13-2005, 08:54 PM
Re: Re: 2000 Cavalier Brake light Probs
Thanks for the idea. Already did the bulbs, so maybe you're right.
Guess I could check to see if I have any power coming there when the brakes are applied.
Any other ideas??
Old 02-16-2005, 03:42 PM
lorazepam lorazepam is offline
just wondering if you figured out problem cause i am having similar problem----mine are working intermently-----they seem to work when i use turn signals----top one always works
Old 02-18-2005, 09:43 AM
billyboyb billyboyb is offline
Any ideas???
Thanks,
Billy
there is a recall at your chev dealer for that problem
re-call number 04083
check it out........
Old 02-18-2005, 09:20 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
pop out the bulb and look into the socket, if theres bunch of brown crud inside there or even a little of that shit, you got to replace the socket, the damage wasn't that bad, about $10.00 from the dealer.
Old 02-18-2005, 09:32 PM
hopeless4life hopeless4life is offline
Send a message via MSN to hopeless4life
are your blinkers working because if they aren't and the high mount brake light is working, turn the hazard lights on then off. What happens in ALL newer cavaliers and sunfires, if the hazard switch gets stuck in the middle (not on or completely off) Its causes the brake lights and turn signals not to work. This is because when your hazards are on your brake lights and turn signals won't work, thus if the switch is in the middle the circuit is not completed.
Old 02-18-2005, 10:59 PM
IFIXCARZ4U IFIXCARZ4U is offline
Cavalier brake lights
There is a recall on taillight sockets from GM. Go to your nearest Chevy Dealer and they can check to see if your vehicle is covered under the recall. If it is they will replace both sockets and bulbs
Old 02-19-2005, 12:18 PM
Re: Cavalier brake lights
Thanks Everyone!!! I'll give all your suggestions a try!
All the other light functions work perfect. It's only the brakes.
Old 12-04-2005, 08:39 AM
cherrera2112 cherrera2112 is offline
[quote=hopeless4life]are your blinkers working because if they aren't and the high mount brake light is working, turn the hazard lights on then off. ...
ttthhhaaannkk uuuuuuuuuuu so much for that advice!!!!! godsend
Old 01-02-2006, 01:29 PM
cusefan cusefan is offline
Turn signal
I had the same problem and actually had to replace the entire turn signal relay in my steering column...now no problems.
Old 03-07-2007, 07:51 PM
TooMuchRock TooMuchRock is offline
that recall is for the 2003 cavalier.
Did anyone ever get their 2000 cavalier problem fixed, as i am having the same issue. Tried replacing the brake switch, that didn't work.
None of the 3 brake lights will work, neither will the blinkers.
