Old 02-13-2005, 12:06 PM
MrTaurus MrTaurus is offline
93 Taurus Overheating Problem - Timing belt?
Hello. Thanks for helping me out. I have a 93 Taurus 3.0 with 115k miles and it is overheating. I am not a very mechanically able person and that is why I am seeking help. The car does have coolant in it and it is not leaking. Originally I thought it might be the thermostat but when the engine turns over there is a rattling/belt broken loose noise coming from the left side of the engine near the alternator. None of the visible belts are broken or loose though.
While I was tring to diagnose the problem a gentleman walked by, heard the noise and told me that my timing belt was broken, and therefore it took out my water pump. Does this sound like the problem? I thought if the timing belt went bad that the entire car would be affected (tranny, engine might not even start, etc.)
Any help would be greatly appreciated....
Paul~
Old 02-13-2005, 01:21 PM
hughw hughw is offline
If your timing belt was broken, the car would not be running....and that would not cause a heating problem...car just would not run...The noise could be coming from the water pump....I dont have first hand experiance with tauras water pumps..so I won't attempt to advise any more on that....When car is overheating with no leaks...it is most likely the thermostat....Hopefully you can get more input about the noise.
Old 02-13-2005, 03:30 PM
Howdy and thank you for your reply. I originally also thought it might be the thermostat, although I have purchased a new one I have not installed it. What about the noise? If it was only the thermostat, would there still be the rattling/broken belt sounding noise? I did do a little further investigation and noticed that the gear attached to the water pump was wiggling. So now I think that it is probably the water pump. Any ideas or suggestions?
Paul~
Old 02-14-2005, 12:01 AM
mlw35405 mlw35405 is offline
Re: 93 Taurus Overheating Problem - Timing belt?
Yep, what you describe sounds like a bad water pump bearing. The water pumps on the 3.0 are not run by a timing belt. As a matter of fact, the 3.0 does not even HAVE a timing belt, rather a timing chain that usually does not wear out and is not related in any way to the water pump. Replace the water pump and thermostat (parts will run around 50 bucks) and you should be on your way.
The young and the young at heart wait,
But the wait never ends in the soul,
When you feel like its all blown away,
Independence has come,
And into the night I go...
Old 02-14-2005, 03:17 PM
Paul~
I looked at the water pump replacement in my Haynes manuel...and it is as simple as any and simpler than most....Gasket scraper and ratchet in hand should make a fairly easy job. (I would have expected a leak from the water pump if the shaft is loose...eventually it will start leaking)
Have fun.
Old 05-24-2005, 04:34 PM
vampiro03 vampiro03 is offline
are you sure the noise isn't coming from your exhaust? the flex pipe when cracked makes a noise a lot like your describing.
Old 05-27-2005, 10:40 PM
Ironmike215 Ironmike215 is offline
Send a message via AIM to Ironmike215
Sounds almost exactly what mine's doing
I also have a 93 taurus with the 3.0 in it, and I have noticed a few things with mine. one being that the damn thing went through 2 sepentine belts in about 5 months (which was probably due to the tensioner being screwed), the second being that the water pump on that thing does not look like a very fun job to do. Here's what was up with mine: I had a similar problem with the thing getting pretty hot, which living in florida i am sure is part of the equation since it gets hot as hell down here this time of the year. On its most recent trip to the shop, I had the auto-tensioner for the serpentine belt replaced and it seemed to fix the problem, but as of a few weeks ago, that fix was only temporary as the thing is getting hotter than normal, and with a 114k a water pump/thermostat sounds about right for me. anyways, I would be interested in hearing how you made out with the water pump. also I would have to agree with vampiro, a cracked flex pipe does make that sound, i know, i have one, and it is probably related to my heat problem, however mine also exhibits symptoms of the thermostat sticking. oh well...such is life, good luck with the pump.
