Old 02-13-2005, 11:02 AM
In_Style In_Style is offline
Will a bad TPS couse misfire?
I read my codes and it says the TPS is failing and I have a misfire on cylinder #3. Also when have it in park and rev it up it blow black smoke. Burning rich but the codes say nothing about the o2 sensor. Might it be just the TPS?
Old 02-13-2005, 11:22 AM
dickswhip00gs dickswhip00gs is offline
Re: Will a bad TPS couse misfire?
most likely. black smoke usually indicates gas, and white usually oil.
Old 02-13-2005, 07:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
it could be. i would fix it and clean/replace the plugs then see if the codes come back
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-14-2005, 01:43 AM
kjewer1 kjewer1 is offline
AF - Advisor
Coolant is white, oil is blue, fuel is black. But in most cases these colors are so damn close to each other you're fooling yourself if you think you can tell. Sometimes it is obvious though. Its actually easier to go by smell.
TPS doesnt really do much. It wont affect thigns enough to cuase a misfire or smoke. The ECU uses airflow per rev and a few other parameters to determine AFR, TPS is not used. It does however proved an accelerator pump function, like the old carbeurated motors mecahnical accelerator pump.
Edit> It also wouldnt cause a misfire specific to cylinder 3. It would random, ethier in specific cylinder DTCs, or as an actual Random Misfire DTC. Typically, if the cylinder that is getting the code is conistent, it is something to do with that cylinder.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
