Go Back   Automotive Forums Car Chat > Ford > Contour
Old 02-13-2005, 10:49 AM
99contourw/problem 99contourw/problem is offline
Unhappy in need of help
I need help, I have a 99 ford contour that has been on a downhill since summer of 04. First fuel pump, then timer belt, and I do not know what is going on . It started with the check engine light, I got a oil change still set. I started to notice that I was not getting any power it is like It was dying on me. suddenly it did, while driving to the gas station the car engine just stop running, I put gas in it and got a jump it turned very weekly ran for a minute then shut itself off again. if there is anybody out there with simuliar problems or a solution please advise me.
thanks
Old 02-13-2005, 12:59 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Im assuming its a 4 cylinder?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-19-2005, 05:38 PM
Tagg99 Tagg99 is offline
Re: in need of help
Sounds like the fuel pump .hope it helps
Old 02-20-2005, 03:31 PM
Jason43's Avatar
Jason43 Jason43 is offline
Re: in need of help
Usually the fuel pump, which is a known problem on the returnless fuel tours, doesnt cause it to stall completely. You would notice a lack of power at wide open throttle.
Have you gotten the check engine light checked out? If you could get the code pulled and let us know what it is, that would be a start.
Just go to contour.org
1999 Ford Contour SVT
