Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 02-13-2005, 09:16 AM
mrSparkle mrSparkle is offline
Car jerking to left
After about 5-10 minutes of driving my car starts jerking to the left pretty hard. Also it makes a loud clanking/rubbing noise. Also it only does this why I am accelerating. I was wondering if you had any ideas on what could be causing this.
Old 02-13-2005, 10:28 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
Re: Car jerking to left
My guess would be a front end alignment.
Old 02-14-2005, 01:11 AM
BullShifter's Avatar
Re: Re: Car jerking to left
Frozen brake caliper
Old 02-14-2005, 02:10 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
oh, piston is frozen clamped. How does this occur?
Empty Pockets Racing Member #1
Old 02-16-2005, 12:11 AM
I doubt it's the caliper's piston, but I do think it could be a frozen slide.
How does it happen? IMPROPER MAINTENANCE! Brakes need to be inspected, cleaned, LUBED. At least once a year a brake service should be performed.
How to do it? www.helminc.com nothing beats a factory repair manaul.
Last time I explained a brake service the moron thought the lube goes on the inside of the pads(part that touches the rotor) while it actually goes on the back. So I'll leave that information to be found in the repair manual. If you can't follow that, you shouldn't be working on your car.
Old 02-17-2005, 10:52 AM
94hondaacc 94hondaacc is offline
Get That Checked Asap!!!! You Are Playing With Your Life. Cmon You Should Have That Checked Immediately And Then Tell Us What Happened, Have Your Car Maintainced Regularly, This Is The Type Of Stuff That Causes Accidents, And That Sucks Too.
Old 03-22-2005, 06:26 PM
Icantgetno Icantgetno is offline
sounds to me like what i was having happen with my axels when i lowered my car witha B16 in it, solved the problem by putting Raxels in it, they were binding because the old ones were too long for the alignment with the lowered suspension.
