Old 02-13-2005, 08:29 AM
minidreams_n_scale minidreams_n_scale is offline
Does the Fujimi red plastic Bleed !
I just started working on my frist colored fujimi kit ,and wanted to know if the red dye bleeds after is is paint , I have a wild 2 tu tone idea ,but before i start on it i was woundering if anyone ever had trouble with the dyes ! Thanks , I will post pics later ! By the way its the Toyota ae 86 2 dr coupe !
My new toy ! Just picked this up 1 owner ! Car is very , very clean but has 168,000 miles !
I heard a rumor that these cars are bullet proof and can be made into monster's
Frist day home 12/12/07
Old 02-13-2005, 09:26 AM
ZoomZoomMX-5's Avatar
Is there any way to test the paint on any of the parts?
Recently I've painted two Japanese kits molded in red...a Rosso 512 TR and a Hasegawa Miura, both primed w/Tamiya light gray primer and coated w/Cobra Colors Grigio Alloy (light blue metallic) w/o any problems w/color bleed. But I did paint a yellow Fujimi RX8 where the Tamiya white primer seemed to be bleeding the yellow through...or perhaps the primer wasn't covering, I switched to a coat of gray primer and back to white, and the pearl white paint I applied over that is pure pearl white w/o yellow color bleed.
If you're shooting hot colors such as spray cans of Black Gold you might have some problems (color bleed/plastic etching) since it's very hot paint. You'll need a good primer/sealer coat on the model. If you airbrush Black Gold/HOK paints mix 'em w/Gunze Mr. Thinner and spray light coats, the plastic should be fine.
My Fotki Album
