Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 02-13-2005, 02:58 AM
98 4life 98 4life is offline
20 in wheels
Hi all. Here's my problem I have 20in.wheels&tires on 1994 olds.98 sd.
the front's OKAY. But the wheels on the back are scrubing againt the fender
is there anything I can use to get aleast 4in. of lift beside the kit that
goes in the springs. PLS help in Millington. Don't know what to do at
this point.
Old 03-20-2005, 05:18 PM
Olds98 Olds98 is offline
If you don't want to use spring boosters, another option might be an adjustable airbag suspension, but that will cost some money. A trick a lot of racers do when they stuff big tires in a car is to roll the fenders for clearance. This might be an option for you. Check with a bodyshop that does performance work
Old 03-21-2005, 06:13 PM
Re: 20 in wheels
I'm not sure what rolling the fenders are but
please explain . 98 4life
thanks again.....
Old 03-22-2005, 08:31 PM
It's a modification that can be done fairly simply by a bodyshop, basically involves a slight reshaping of the metal to increase clearance between the fender and the wheel. Don't know if its an option for you but trying a wheel with a different offset my also help
