Old 02-13-2005, 02:48 AM
steve_tracer steve_tracer is offline
Question '95 tracer ignition relay location?
Anyone know where this booger is located in my 1.9L car? My schematics show it to be in engine compartment fuse box, but all I see there is a cooling fan relay and some fuses. I can push car off and all is good, but this is a pain. Is this part located up under this box maybe? I have replaced battery, starter, starter relay, checked and ohmed wires, and it appears I'm not getting fire to the starter on the clip connector with the key switch ON. Is there some inline fuse I'm missing? Didn't see one in the schematics. Any other suggestions for this no start problem would be appreciated. Thanks, Chevy guy for your earlier input!
Old 02-13-2005, 06:33 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: '95 tracer ignition relay location?
cant help ya on this one but on my car i think its at the bottom of the steering column.
btw almost sounds like the problem I had and turned out to be the computer.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 02-13-2005, 11:01 AM
A. Souphound A. Souphound is offline
Check the ground cable/straps between the chassis and the engine. Should be two (2)
Remove the push-on connector on the starter solonoid. Put the transmission in 'Neutral" hook a jumper wire from the (+) battery terminal to the exposed terminal on the relay. The engine should crank. If it does, the problem is in the ignition switch or clutch interlock switch.
Alvin.
Old 03-18-2005, 03:26 AM
You were right about the ignition switch, Alvin!
Thanks!
