Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-13-2005, 12:02 AM
'94bird '94bird is offline
Replacing oil pan gasket on 4.6
I need some info on how to replace the oil pan gasket on my 4.6,
it seems that the frame covers the oil pan.
Old 02-13-2005, 02:32 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Replacing oil pan gasket on 4.6
Pull the engine.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 02-13-2005, 03:15 PM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Or drop the K-member: Info on Dropping K Member
Old 02-13-2005, 03:30 PM
97Bird's Avatar
97Bird 97Bird is offline
Go to helminc.com and order the factory service manual for full instructions. Disconnect battery ground cable
Drain cooling system and remove upper radiator hose, fan and shroud
Disconnect fuel lines
Remove windshield wiper governor and support bracket
Recover a/c system and disconnect outlet hose at compressor. Then remove bolt retaining hose to coil bracket.
Remove fuel charging wire 42 pin connector from power brake booster and then disconnect the 42 and 8 pin connectors.
Remove all hoses to the EGR valve and the EGR back pressure transducer.
Remove EGR valve and tube to exhaust manifold.
Remove the bolts that retain the heater hose to the cylinder head and disconnect the heater hose.
Drain oil
Disconnect the exhaust system at the manifolds.
Loosen but don't remove the two nuts on the transmission insulator.
Remove the engine support insulator through bolts on both sides. (2 on left side and 1 on right side)
Place a jack and block of wood under the oil pan in back of the drain plug and jack up engine about 4 inches.
Place a 2.5-2.75 inch thick block of wood under both engine support insulators and lower engine onto them.
Jack up the transmission extension housing slightly to remove the oil pan.
Remove oil pan bolts and then the pan.
You may have to remove the 2 bolts holding the pick up tube to the oil pump and the 1 bolt holding the tube to the main bearing stud spacer.
That's all there is to it!!!! These instructions are for a 97 but should be a good guide to a 94. As I said, buy the service manual at helminc.com for full details on your year Bird. GOOD LUCK!
